It is currently Sat Aug 29, 2026 8:12 am
 Post subject: G'Mic colorize interactive problem
PostPosted: Wed Jan 01, 2020 11:23 am  (#1)
Hello All,
Have used Gimp for many years now. Using version 2.10 Linux
When I try and use the G'Mic interactive colorize plugin after getting the image the way i like it. the progress bar at bottom is 'working',,,and have let it run as long as 45 minutes and never completes. This is the first time i've used this particular plugin and not sure what i should actually be seeing. Have closed the program a few times and started again. On a fairly nice hardwared computer with 32 GB of ram etc.
Any way to troubleshoot this?
Thank You
 Post subject: Re: G'Mic colorize interactive problem
PostPosted: Wed Jan 01, 2020 12:31 pm  (#2)
Welcome to Gimp Chat, brcisna. :)
PostPosted: Wed Jan 01, 2020 5:13 pm  (#3)
Testing Linux (Xubuntu 18.04.3) Gimp 2.10 G'mic colorize interactive.
1. Picked some random palette to use. Click apply.
2. Added control points using different colors from the palette. Once done, hit Enter on keyboard.
3. The interactive window closes, click OK.
