It is currently Sat Aug 29, 2026 7:31 am
 Post subject: Gimp Improve/sharpen
PostPosted: Tue Jan 07, 2020 3:12 am  (#1)
Hi there,
with my Gimp version 2.8.14 there was a script
called sharpen under filter improve. The script is
no longer available in version 2.10.12.
Is it still possible to download somewhere?
Best regards, Hardy
 Post subject: Re: Gimp Improve/sharpen
PostPosted: Tue Jan 07, 2020 3:16 am  (#2)
Taken from a portable windows 2.8.22 version.
Regards
nelo
PostPosted: Tue Jan 07, 2020 3:27 am  (#3)
Hello Nelo,
thank you very much that was exactly the plug-in I was looking for.
Also works without problems under 2.10.12.
Best regards, Hardy
PostPosted: Tue Jan 07, 2020 7:35 am  (#4)
There is no need to bring over the old sharpen filter, it's already included in Gimp 2.10x. Just search for it using the "/" key on your key-board.
PostPosted: Tue Jan 07, 2020 4:06 pm  (#5)
You can even put it back in the menus:
Edit the pluginrc file and:
- locate the string "_Sharpen..."
- replace the "0" in the next line by "1"
- under that line insert "(menu-path "<Image>/Filters/Enhance")"
So the file should look like:
(plug-in-def "${gimp_plug_in_dir}/plug-ins/sharpen/sharpen" 0
    (proc-def "plug-in-sharpen" 1
         "Make image sharper (less powerful than Unsharp Mask)"
         "This plug-in selectively performs a convolution filter on an image."
         "Michael Sweet <[email protected]>"
         "Copyright 1997-1998 by Michael Sweet"
         "1.4.2 - 3 June 1998"
         "_Sharpen..."
         1
        (icon icon-name -1 "")
         "RGB*, GRAY*"
         4 0
        (proc-arg 0 "run-mode" "The run mode { RUN-INTERACTIVE (0), RUN-NONINTERACTIVE (1) }")
        (proc-arg 13 "image" "Input image")
        (proc-arg 16 "drawable" "Input drawable")
        (proc-arg 0 "percent" "Percent sharpening (default = 10)")))
This will even survive changes in other plugins that would cause the pluginrc file to be updated.
PostPosted: Wed Jan 08, 2020 9:52 am  (#6)
Hi there,
I would like to thank you
again for your help.
Thank you very much
and best regards Hardy
