Custom_Font_WordWall_v001.zip [15.5 KiB]
Downloaded 110 times
I wanted to try and create a filter to help showcase some of the amazing custom fonts that people like Alan and GJL produce weekly, if not daily, on GimpLearn: Some of their results are like miniature works of art.
This plug-in will take text (short messages are ideal) and display it a number times across an image using a selection of custom fonts from a designated folder. The text can be displayed horizontally, vertically or diagonally. There are also options to adjust the spacing between characters, to add a basic drop shadow and to shuffle the order of the layers.
Download, unzip and put the filter in your usual user plug-ins folder.
Create a new image and open the filter dialog:
Filters>>Custom Font Tools>>Custom Font WordWall v.001
More info here on using the filter on GimpLearn:
Link to GimpLearnExample result using recent Custom Fonts by GJL:
