It is currently Wed Nov 18, 2026 9:31 pm
 Post subject: Canny Edge Detection Gimp 2.10 Linux 64 bit
PostPosted: Thu Feb 13, 2020 3:42 pm  (#1)
For those interested. Linux 64 bit version. At first I thought it did not work. Needed an extra click on the menu shortcut and it can generate error messages.
However FWIW zipped and attached. All-in-one example.
canny-linux-64bit.zip [11.01 KiB]
Downloaded 256 times
 Post subject: Re: Canny Edge Detection Gimp 2.10 Linux 64 bit
PostPosted: Thu Feb 13, 2020 4:16 pm  (#2)
Thank you. Yeah I forgot to mention the double-click problem. But I remember placing G'mic on the main menu earlier and it did the same thing.
The one I compiled yesterday was for 2.8. Tried first on 2.10 but there was lot of deprecated calls.
How do you fix them? I replaced them in the .c file but didn't manage to fix it.
PostPosted: Fri Feb 14, 2020 5:13 am  (#3)
...Tried first on 2.10 but there was lot of deprecated calls.
Compiled in a 'buntu 18.04 (VM) Gimp 2.10 and yes, plenty of deprecated call warnings, but they are just warnings not errors. Proving the plugin works with Gimp compatibility, I just ignore them. The plugin is not alone ;) I get plenty warnings from more recent code, gimp_gmic or BIMP for example.
PostPosted: Fri Feb 14, 2020 6:12 am  (#4)
At first, it wouldn't work no matter how many times it was clicked. It was grayed out. I then realized I had to remove the Alpha Channel first. Then it worked.
How to move this to Filters > Edge-Detect?
PostPosted: Fri Feb 14, 2020 8:13 am  (#5)
There is actually a "To Do" comment in the code for that, so recompiled. Try the attached, find in Filters -> Edge-Detect -> Canny
canny.zip [11.02 KiB]
Downloaded 231 times
PostPosted: Fri Dec 12, 2025 9:59 am  (#6)
Hello. Can you please upload the original source .c file? I need to recompile this for the latest gimp libs. Thanks
PostPosted: Fri Dec 12, 2025 2:20 pm  (#7)
There you go: Remember it is for Gimp 2.x
canny.zip [11.49 KiB]
Downloaded 81 times
