It is currently Fri Aug 28, 2026 9:38 am
 Post subject: Mike Licence Plate plugin for Gimp 2.10
PostPosted: Wed Feb 19, 2020 11:52 am  (#1)
Tin Tran wrote a cool plugin to make Licence Plates called "Mike Licence Plate". It doesn't work with Gimp 2.10, so I edited the script so that it now works. Be sure to have an image open before you run the script.
210-Mike_License_Plate.py.zip [2.21 KiB]
Downloaded 347 times
 Post subject: Re: Mike Licence Plate plugin for Gimp 2.10
PostPosted: Wed Feb 19, 2020 2:25 pm  (#2)
it works for me in 2.10.. windows 64 bit. My outcome is just flat. Doesn't look like a real license plate.Image
PostPosted: Wed Feb 19, 2020 2:55 pm  (#3)
It requires LayerFX. Perhaps you don't have that installed?
PostPosted: Wed Feb 19, 2020 3:10 pm  (#4)
mackenzieh wrote:
it works for me in 2.10.. windows 64 bit. My outcome is just flat. Doesn't look like a real license plate.[ Image ]
It looks like no bump-mapping has been utilized.
PostPosted: Wed Feb 19, 2020 3:34 pm  (#5)
Working great for me, thanks racer-x :bigthup
PostPosted: Wed Feb 19, 2020 4:01 pm  (#6)
I have Layerfx installed.. this license plate came from Tin's plugin.. not your updated version.
PostPosted: Wed Feb 19, 2020 4:03 pm  (#7)
The plugin I have is Tin's version.
PostPosted: Thu Feb 20, 2020 3:47 am  (#8)
I am now using the version that racer- x has modified in order to get it to work in 2.10 and I still get a somewhat flat version of a license plate: Image
PostPosted: Thu Feb 20, 2020 3:48 am  (#9)
That's probably it.
PostPosted: Thu Feb 20, 2020 5:47 am  (#10)
Get rid of Gimp 2.10.14, it has a problematic bump-map. This has been discussed numerous times already. It effects many plugins that use bump-map, such as LayerFX.
PostPosted: Thu Feb 20, 2020 9:41 am  (#11)
I don't use LayerFX.scm, only LayerFX.py is all you need.
layerfx.py.zip [28.4 KiB]
Downloaded 345 times
PostPosted: Thu Feb 20, 2020 12:02 pm  (#12)
I'd like to ask you if I go to Filters-Map-Bump Map is it supposed to do something. It has no effect whatsoever on my installation of 2.10.15 and it didn't on 2.10.14 either.
It won't do anything until you point to the bump map you created, either on another layer or image.
PostPosted: Thu Feb 20, 2020 2:27 pm  (#13)
Getting rid of Gimp 2.10.14 won't solve the bump map problem.
PostPosted: Thu Feb 20, 2020 3:22 pm  (#14)
Does your layerfx work? Example "Bevel and Emboss"
PostPosted: Thu Feb 20, 2020 4:43 pm  (#15)
I forgot how Bevel and Emboss work with Layerfx. I know it needs a layer, but what type of layer?
PostPosted: Thu Feb 20, 2020 5:13 pm  (#16)
You can use a simple text layer.
PostPosted: Thu Feb 20, 2020 6:38 pm  (#17)
This is what I get: I ran it on the default settings:
To me, it still looks flat.
Here's another example:
PostPosted: Thu Feb 20, 2020 9:09 pm  (#18)
It's flat because your Gimp 2.10.14 has issues with the bump-map. You'll see it effects many plugins that use bump-map.
PostPosted: Thu Feb 20, 2020 9:45 pm  (#19)
When ever I use other plugins that use bump-map, the outcomes for them, come out fine.
PostPosted: Fri Feb 21, 2020 1:46 am  (#20)
CtrlAltDel wrote:
Mackenzieh, as you can see from the thread, I was having some problems with Mike License Plate but, I was not using Gimp 2.10.14. I had, I believe, an outdated layerfx.py plugin and an unneeded layerfx.scm script. I deleted the layerfx.scm script, used the layerfx.py plugin that Racer-X provided and also his updated MikeLicensePlate.py plugin.
All of this worked for me, but I also wasn't using 2.10.14 which is known to have issues. I know it's hard to change Gimp versions for many people that are using PPA's, for example, but you should try. You probably shouldn't upgrade at this time to 2.10.5 or 2.10.7, which is out now on the AppImage site, because then you have issues with changing fonts and gradients, etc... in varied plugins.
I downgraded, using the AppImage, to 2.10.12 and everything works. Again, I don't know your OS or in which way you are installing Gimp but, it's worth a try to ditch 2.10.14 and try another version if it's not too great a problem.
Here:
is an old license plate I made months ago using 2.10.14. It just doesn't work. I thought that is how they were supposed to look until I read this thread and saw the good examples of how it's really supposed to be.
Hi, thanks for the reply. The OS, I have is Windows 10 64 Bit. I just deleted layerfx.scm. I have the updated layerfx.py file that racer-x updated. Gimp.org still doesn't have the new version up yet, so I'll wait on that.
