It is currently Sat Aug 29, 2026 6:15 pm
 Post subject: Re: Invalid parameter name dialog status error
PostPosted: Thu Feb 20, 2020 9:04 pm  (#1)
It's a bug in Gimp 2.10.16. viewtopic.php?f=7&t=18032&p=247671#p247654
Hopefully it will be fixed before the official release.
PostPosted: Tue Apr 14, 2020 3:59 pm  (#2)
I am having similar problem in Gimp 2.10.18
Plug-in "script-fu.exe"
(C:\Program Files\GIMP 2\lib\gimp\2.0\plug-ins\script-fu\script-fu.exe)
attempted to install procedure "temp-procedure-number-3" with invalid parameter name "dialog status".
Trying to change font in create logo section of program "cool metal"
Operation systems Windows 7 and 10
Similar issues with other scripts elsewhere in program.
Thanks in advance for any help.
PostPosted: Tue Apr 14, 2020 11:23 pm  (#3)
Use SamJ Portable version. Scroll to the middle of the page:
https://samjcreations.blogspot.com/2020/
PostPosted: Wed Apr 15, 2020 2:24 am  (#4)
Should be fixed in 2.10.20 .... we'll just have to wait till its ready to be released
Regards
nelo
PostPosted: Tue Apr 21, 2020 4:44 pm  (#5)
I have seen a similar in scripts that a pattern such as texturizer, also it does not matter whether it is scm or python script.
