It is currently Fri Aug 28, 2026 7:11 pm
 Post subject: Scripts that don't work properly
PostPosted: Wed Mar 18, 2020 2:12 pm  (#1)
Here's a list of the scripts I've found that don't work properly when trying to change gradients or patterns, or what have you. They are all found here: File>Create>Logos
Cool Metal Script:
3D Outline:
Blended:
Chip Away:
Comic Book:
Glossy:
 Post subject: Re: Scripts that don't work properly
PostPosted: Wed Mar 18, 2020 3:13 pm  (#2)
It's not the scripts, it's your version of Gimp that's the problem.
PostPosted: Wed Mar 18, 2020 3:16 pm  (#3)
I have the latest version of gimp (2.10.18) windows 64. I don't see how that's the problem but if you say it is, then it is.
PostPosted: Wed Mar 18, 2020 3:30 pm  (#4)
You need to use a Gimp version with the fix, I don't know the Windows version that you would need. Someone with Windows needs to respond here.
PostPosted: Wed Mar 18, 2020 3:45 pm  (#5)
As far as I understand what's in the bugtracker it'll be fixed in 2.10.20.
Hopefully ...
Regards
nelo
PostPosted: Wed Mar 18, 2020 4:28 pm  (#6)
Hopefully ...
Thanks for the info nelo.
