It is currently Sat Aug 29, 2026 6:15 pm
 Post subject: glass-frame-effect.scm
PostPosted: Thu Mar 26, 2020 3:56 am  (#1)
Hi there,
is the filter "glass-frame-effect.scm" already
adapted for the new Gimp and G'Mic version?
If so, I am very grateful for a link to download!
Greetings from Germany and everyone stays healthy !!!
 Post subject: Re: glass-frame-effect.scm
PostPosted: Thu Mar 26, 2020 7:08 am  (#2)
Here the filter running on 2.10
DIEGO_FRAMES_GlassFrameEffects210.7z [5.41 KiB]
Downloaded 496 times
PostPosted: Thu Mar 26, 2020 7:26 am  (#3)
It requires "MyGlass_15.jpg" pattern to work. Maybe you should also post the MyGlass_15.jpg?
PostPosted: Thu Mar 26, 2020 7:40 am  (#4)
It is in an earlier post along with some others
viewtopic.php?f=9&t=14962#p208326
PostPosted: Thu Mar 26, 2020 9:26 am  (#5)
Hi there,
the filter works well.
Where do the GI Presets for
GlassFrameEffects have to be installed?
Best regards, Hardy
PostPosted: Thu Mar 26, 2020 9:55 am  (#6)
Under Preferences/gimpressionist/
(at least in my samj's portable pack)
PostPosted: Thu Mar 26, 2020 10:22 am  (#7)
Hello Dinasset,
thank you very much it works now.
But the plug-in cartoon is still missing.
Can you tell me where I can get that?
Best regards and stay healthy Hardy
PostPosted: Sat Mar 28, 2020 2:19 am  (#8)
Hello Deigo
Can you please help with a problem running this scm.
I am using Windows 10. 64 bit Gimp 2.10.12
When starting up the script I get a black screen which does not go away until the process has finished. The end result is O.K.
In Preferences there is no longer a gimp impressionist folder. So where can I place the G1 presets.
Thank you
PostPosted: Sat Mar 28, 2020 2:52 am  (#9)
hardy111 wrote:
Hello Dinasset,
I have this one in Samj's portable pack.
cartoon.7z [17 KiB]
Downloaded 432 times
PostPosted: Sat Mar 28, 2020 2:56 am  (#10)
P1937 wrote:
Hello Deigo
Thank you
Create both:
- under Preferences create folder gimpressionist
- under Preferences/gimpressionist copy the Presets folder I attached previously
edit: about the black screen I do not know, I use Samj's portable
PostPosted: Sat Mar 28, 2020 4:05 am  (#11)
When trying to run Glass Frame Effect in Gimp 2.10.18, I have this error: Image
Why is that?
I also have these errors:
PostPosted: Sat Mar 28, 2020 4:19 am  (#12)
Hello Dinasset,
I would like to thank you again for
the "cartoon.exe".
Greetings from Germany and stay healthy !!!
Hardy :tyspin
PostPosted: Sat Mar 28, 2020 4:23 am  (#13)
@ P1937
Is this really script-fu (scm)? No plugin python?
@ Mackenzieh
You should know the solution.
viewtopic.php?f=9&t=18138&start=30#p249000
PostPosted: Sat Mar 28, 2020 4:54 am  (#14)
Thank you Dinasset your post #10. I will give that a go.
MareroQ you are quite right glass frame is a plugin not a scm.
Too much self isolation not thinking straight.
Can you help with the black screen please.
PostPosted: Sat Mar 28, 2020 5:10 am  (#15)
For Windows and Gimp from gimp.org and the Partha version, the initial 2 line is required:
#!/usr/bin/env python
# -*- coding: utf-8 -*-
Included in the attachment (for lazy users... :lol ).
Edition:
Author's version in post # 18
Instead of a code, a screenshot the shebang.
@Diego
In all plugins "Repository for Special Editions of Dinasset's filters"
viewtopic.php?f=9&t=14962&start=0
they are missing of this code - maybe just add information ?
PostPosted: Sat Mar 28, 2020 7:04 am  (#16)
@Diego
Thanks, I will try to remember it, when someone else will ask for one of my previous plug-ins (but it's quite difficult, because since years I use Samj's packages and I never had such a problem)
PostPosted: Sat Mar 28, 2020 1:26 pm  (#17)
@Dinasset
I have tried inputting the code and I still get this error:
Here is the code:
If I am inputting the code wrong, where does it go? I used NotePad since NotePad++ won't allow me to save the code. I am not a coder.
PostPosted: Sat Mar 28, 2020 1:43 pm  (#18)
Try my current version and cross the fingers...
DIEGO_FRAMES_GlassFrameEffects210.7z [5.42 KiB]
Downloaded 277 times
PostPosted: Sat Mar 28, 2020 2:52 pm  (#19)
What size do images have to be so that the plugin will work properly? I ask because it throws an error:
PostPosted: Sat Mar 28, 2020 3:54 pm  (#20)
The message tells it to you:
minimum width=640
minimum height=640
In other words: the smallest side must by >=640
