It is currently Fri Aug 28, 2026 12:04 pm
 Post subject: Find and fill paths if closed, convert closed paths to transparent
PostPosted: Wed Apr 15, 2020 12:32 pm  (#1)
Is it possible to do this in script-fu?
Go from Pronghorn.png, which has a transparent background.
Here's how I did it manually:
Select the open paths (lines in the head and on leg and thigh) and fill them with white.
Select the area just inside the closed path that makes up the outer edge of the Pronghorn.
Fill that area Black. This leave the 'islands' I want to keep transparent.
Ideally I should have selected the 'white' open paths and filled them transparent before saving.
I have about 3000 images to process so, I'd like to be able to script it. I just don't know how to find the open paths, then fill inside the outer closed path.
Thank you
 Post subject: Re: Find and fill paths if closed, convert closed paths to transparent
PostPosted: Thu Apr 16, 2020 3:43 pm  (#2)
This image likely comes frorm some vector graphics app (SVG, AI or EPS format). Do you have the vector files? This would be a lot easier.
