It is currently Sat Aug 29, 2026 5:52 pm
 Post subject: Seamless wood slat Pattern.scm
PostPosted: Tue Apr 21, 2020 1:39 pm  (#1)
Hi everyone, I will like to share my very first script that creates a seamless wood pattern with divisions (slats).
I will like to thank ofnuts for some pointers, and specially JimmyMarco for the definitions in some of the error. Also I will like to thank and give credit to Conbagui from deviantart for the tutorial and to allowed me to create the script from it. This is the sample of the pattern
***This script requires Plasma2 plugin from one of our own Photocomix. You can download it @ http://fav.me/d1cde5x
seamless-wood-slat-pattern.zip [47.88 KiB]
Downloaded 81 times
 Post subject: Re: Seamless wood slat Pattern.scm
PostPosted: Tue Apr 21, 2020 2:51 pm  (#2)
This requires installed plugin "Plasma2", which I don't have and therefore can't test. Perhaps you could disclose list require plugin dependencies.
PostPosted: Tue Apr 21, 2020 3:05 pm  (#3)
Hello, :)
Plasma2 plugin is available for Windows here :
https://samjcreations.blogspot.com/2018 ... ts_24.html
And here :
http://www.aljacom.com/~gimp/greffons.html
Have fun. :)
PostPosted: Tue Apr 21, 2020 3:21 pm  (#4)
Those are for Windows and useless to me and other Linux users. I found a Linux 64 version here and now it works.
viewtopic.php?f=9&t=494&hilit=plasma2&start=40#p174120
PostPosted: Tue Apr 21, 2020 4:16 pm  (#5)
Thank you for the catch, Racer :tyspin . I should it pointed that out. Thank you JimmyMarco for the link :coolthup , I have this plugin for a long time and I downloaded it from deviantart.com. I placed the link on the original post.
