It is currently Fri Aug 28, 2026 7:11 pm
 Post subject: Morphological Operators 1.0 for Linux Ubuntu 64bit
PostPosted: Thu Apr 23, 2020 12:50 pm  (#1)
On request Nidhogg Morphop 1.0
Author:
Alessandro Francesconi
Sources:
https://alessandrofrancesconi.it/projects/morphop/
Menu path:
Filters -> Generic -> Morphological Operators...
Morphop Linux Ubuntu 64bit.zip [25.31 KiB]
Downloaded 185 times
 Post subject: Re: Morphological Operators 1.0 for Linux Ubuntu 64bit
PostPosted: Thu Apr 23, 2020 12:55 pm  (#2)
Awesome, thanks again :bigthup
I didn't have guts to install Focal Fossa yet.
PostPosted: Thu Apr 23, 2020 1:54 pm  (#3)
I think it's worth the wait a bit longer - the update has removed Python's support for Gimp and there is no version yet.
The update also removed all *py files from the Gimp folders as well as pygimp.env and pygimp.interp.
Fortunately, I had a backup - but such removal is a very strange operation. :gaah
ps. Attempting to install (sudo apt install) Python 2.7 in Focal Fossa gives a message:
DEPRECATION: Python 2.7 will reach the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 won't be maintained after that date. A future version of pip will drop support for Python 2.7. More details about Python 2 support in pip, can be found at https://pip.pypa.io/en/latest/d
So all that is left is to use Gimp-appimage with Python.
I need to try the latest version:
GIMP_AppImage-git-2.10.19-20200416-withplugins-x86_64.AppImage
Download:
https://github.com/aferrero2707/gimp-appimage/releases
