It is currently Mon Sep 14, 2026 5:06 pm
 Post subject: Script-Fu Scrolling Interface V1.1 for GIMP 2.10.18 Linux Ubuntu 64bit
PostPosted: Thu Apr 23, 2020 1:05 pm  (#1)
The author of a sensational patch:
GnuTux
Sources:
viewtopic.php?f=9&t=10983
SF-Scrolling-InterfaceV1.1-For-GIMP-2.10.18-Linux_x64.zip [66.3 KiB]
Downloaded 313 times
 Post subject: Re: Script-Fu Scrolling Interface V1.1 for GIMP 2.10.18 Linux Ubuntu 6
PostPosted: Thu Apr 23, 2020 5:21 pm  (#2)
Hi Marero
what was the point of recycling this old script? It's just a hack for poorly written scripts that don't scroll and it breaks Gimp's internal script-fu.
viewtopic.php?f=9&t=16657
I can see you want to save a lot of old code but sometimes that is just dragging problems into the future.
PostPosted: Thu Apr 23, 2020 6:43 pm  (#3)
Hi Tas_mania.
There are undoubtedly many badly written scripts but many of them are irreplaceable. :ninja
Everyone has a choice if they want to use the plug - and I repeat: the scroll bar has never created any problems for me. It is important to use the correct version. Quoted Michael Natterer talks about the problem of using double scripts (identical registration but different codes and name) and not the script-fu plugin.
The real problem is preparing with Python2.7 (end of support) and Gimp 3.0 with Python3 may be in a few years...
viewtopic.php?f=9&t=18260&p=249998#p249998
PostPosted: Thu Apr 23, 2020 7:47 pm  (#4)
This plugin isn't needed in Linux anyway, since you can move the plugin window using the Alt key. The AppImage compensates by default also, assuming you are using the appImage version. Joined up Text is the only plugin I need to move the interface, for that matter.
PostPosted: Wed Jun 23, 2021 2:08 pm  (#5)
:jumpclap
ALT in Linux : that works!! Thank you Thank you .. no plugins necessary
[ dancing at desk ]
(LeftyLeo/James)
