It is currently Sun Aug 30, 2026 11:37 am
 Post subject: Text-embroider
PostPosted: Sun Apr 26, 2020 8:20 am  (#1)
I came across the text embroider script ... somewhere on this site. The results are beautiful. But why can't I succeed? :gaah
 Post subject: Re: Text-embroider
PostPosted: Sun Apr 26, 2020 10:14 am  (#2)
Unfortunately the script is for Gimp 2.8 and uses scripts and plugins that are missing / no longer work with Gimp 2.10
Needed from Gimp 2.8
a script erase-rows.scm
plugins ripple.exe and if using Gimp 2.10.14 bump-map.exe
Give a hint as to which OS (linux / win / 32 or 64 bit) and Gimp version you are using and I am sure someone will post the required files.
PostPosted: Sun Apr 26, 2020 11:01 am  (#3)
Thank you .. besides (Windows) Gimp 2.10.14 I also have 2.8 on it ... I hope someone can help me.
PostPosted: Sun Apr 26, 2020 12:26 pm  (#4)
You will have all the necessary in your computer somewhere ;)
Best advice is use the text-embroider_RD_V-2.0.scm with your Gimp 2.8 - It is made for that. Nothing else to do.
Otherwise, for Gimp 2.10.14 some (Win 64 bit) files zipped and attached.
Unzip. Put bump-map.exe and ripple.exe in C:\Users\"yourname"\AppData\Roaming\GIMP\2.10\plug-ins
and
erase-rows.scm add-bevel.scm text-embroider_RD_V-2.0.scm in C:\Users\"yourname"\AppData\Roaming\GIMP\2.10\scripts
In use: Make sure the text layer is the active layer when applying the script.
note: I did try in a linux 2.10.18 and that had problems with erase-rows. Had to apply that manually after running the text-embroider script.
for-embroider-win-64.zip [57.2 KiB]
Downloaded 222 times
PostPosted: Sun Apr 26, 2020 2:38 pm  (#5)
My thanks are great!
PostPosted: Wed May 13, 2020 9:36 pm  (#6)
I've been trying replicate embroidery on GMIC using various filters and minus some embossing or beveling, this was as close as I could get without utilizing a script. Let me know what you think and maybe offer GMIC filter suggestions. I'd like to just create the entire embroidery filter (with revisions and improvements) and submit it to GMIC, permanently.
This is using Rod's script (the every other line option seemed to be missing, so back to GMIC to add scanlines)
PostPosted: Thu May 14, 2020 12:55 am  (#7)
Thank you for the effort .. looking good!
PostPosted: Thu May 14, 2020 3:49 pm  (#8)
Denim isn't hard to duplicate in GIMP, use a medium blue, add noise, blur, and add diagonal scanlines. Fake seams using bumpmaps and displace (Fencepost tutorial).
The embroidery is trickier, and because GIMP's internal tools change and some are removed, some scripts become obsolete. However, using GMIC and Lyle's Ripple filter, it's possible to get really close. I think some fonts work better than others, like suggested by Ed Merced in his tutorial (Mardian Demo font).
PostPosted: Thu May 14, 2020 9:29 pm  (#9)
That is... wow pretty awesome mahvin :clap . Can you make a tutorial, please? :yr
PostPosted: Thu May 14, 2020 11:05 pm  (#10)
Start here by downloading Fencepost's tutorial, it's an old version of GIMP but still works in the current GIMP.
https://www.deviantart.com/fence-post/a ... P-53850678
That will get you started, while I work on gathering my notes on the embroidery.
PostPosted: Fri May 15, 2020 12:16 am  (#11)
OK, thanks :bigthup
PostPosted: Sat May 30, 2020 1:43 pm  (#12)
Let me know what you think of this example. I'm working at getting as close to perfect as humanly (GIMP) possible before I throw out a tutorial, so in case anyone wants to script it out it will be worth the effort.
PostPosted: Sat May 30, 2020 2:11 pm  (#13)
I don't see anything wrong mahvin, it's just perfect in my eyes. :yes Do the tut please!
PostPosted: Sat May 30, 2020 3:32 pm  (#14)
I like that you are still working on the script.
it looks very good
This is made in Gimp 2.8
PostPosted: Sat May 30, 2020 4:33 pm  (#15)
File comment: You're going to need this, if you don't have it.
Stripes2px.png [ 555 Bytes | Viewed 3364 times ]
Here's the link to the video. I was flying by the seat of my pants with scribbled notes. Post any questions about the video that doesn't seem clear.
https://screencast-o-matic.com/watch/cYhvr6pyMD
PostPosted: Sat May 30, 2020 5:15 pm  (#16)
Thank you for sharing mahvin :coolthup
PostPosted: Sat May 30, 2020 5:20 pm  (#17)
I must agree, Mahvin! It looks perfect.
PostPosted: Sat May 30, 2020 6:13 pm  (#18)
Thank you, everyone.
PostPosted: Sat May 30, 2020 10:45 pm  (#19)
Thank you for the clearly explained tutorial mahvin. I like your results.
I'm using gimp 2.10.10 and find layer effects throws up errors so I may not have the right version.
Bevel and emboss gives
gimp: GEGL-CRITICAL: gegl_node_add_child: assertion 'child->priv->parent == NULL' failed
Inner glow gives:
layerfx.py:2048: Warning: value "0" of type 'gint' is invalid or out of range for property 'area-height' of type 'gint' self.color_button = gimpui.ColorButton("Glow Color", 80, 0, gimpcolor.RGB(255, 255, 190, 255))
They both do something but their results don't really show.
Here's my result anyway:
PostPosted: Sun May 31, 2020 12:01 am  (#20)
Nice job! A little inner glow and a small drop shadow should work it out better.
Maybe update to 2.10.18?
