It is currently Sat Aug 29, 2026 10:57 am
 Post subject: Convert a selection into an array of coordinates/points
PostPosted: Fri May 15, 2020 2:48 pm  (#1)
Hello,
I'd like to know if there's an option to convert a selection (like a selection done using the Fuzzy select tool) into an array of coordinates that comprise that selection.
 Post subject: Re: Convert a selection into an array of coordinates/points
PostPosted: Fri May 15, 2020 2:57 pm  (#2)
ocp1000 wrote:
Hello,
You can use the Select>To Path option,
within the Selection Menu.
PostPosted: Fri May 15, 2020 3:49 pm  (#3)
ocp1000 wrote:
Hello,
If you convert the selection into a path, the path is expressed as a set of cubic Bézier splines (aka "strokes"). There is an API call to interpolate these "strokes" with a polygon of specified accuracy.
