It is currently Mon Aug 31, 2026 2:03 am
 Post subject: Warp Transform tool PDB function? (Solved)
PostPosted: Fri May 22, 2020 7:13 pm  (#1)
Hi my fellow GIMP users, I hope things are going well in the midst of the troubles and are staying safe. I have another question for the GIMP script writer if you don't mind.
Since Gimp 2.10 introduce the new "Warp Transform tool" and omitted the "IWarp" plugin, I can't find a PDB function for the new tool. I wrote a plugin that creates a Glass sphere and I need the Warp Transform for the last part of the script. What is the pdb function? Any help is well appreciated. Thank you in advanced!
 Post subject: Re: Warp Transform tool PDB function?
PostPosted: Sat May 23, 2020 8:57 am  (#2)
AFAIK it is a GEGL function http://gegl.org/operations/gegl-warp.html and therefore not in the PDB
There are notes about scripting here: viewtopic.php?f=9&t=18040
PostPosted: Sat May 23, 2020 10:22 am  (#3)
Thanks a lot rich2005 for the respond. In a way I knew that the developers did not update the PDB to access this new Gegl functions. I had to use some common sense and I went and used a G"MIC filter to compensate for the look I need.
pdb.plug_in_gmic_qt(img, backLayer, 1, 0,
      "-v - -fx_distort_lens 0.1,0,0.16,50,50,0")
It's not bad but i rather have the Transform tool or Lens distortion for this script.
Ps The GIMP Lens distortion pdb function is there but since the plugin is not, it won't give you a good result. As the matter of fact, it gave a horrible result. I will post the plugin soon. Thanks again.
