It is currently Sat Aug 29, 2026 10:57 am
 Post subject: create_glossy_round_button.py
PostPosted: Fri May 29, 2020 12:31 am  (#1)
There is a few plugin that creates web buttons, I don't know if there are any like the one I created with a choice of a Monogram
I wrote this script following steps in Round Web 2.0 Button with a Metal Ring tutorial by Gtust.com found at link: https://web.archive.org/web/20090217010 ... metal-ring
1. It Creates a 450 x 450 px Web 2.0 Button (default), but you can scale it down to 100 px or scale it down to
800 px max.
2. Have an option to create Monogram letter or not on the Button and user select any Font in your system to create the Monogram.
3. User can select the color desire for the Monogram.
This is how th dialog looks like:
create_glossy_round_button.zip [2.26 KiB]
Downloaded 95 times
 Post subject: Re: create_glossy_round_button.py
PostPosted: Fri May 29, 2020 2:05 am  (#2)
Thank you Pocholo
For the nice plugin
I like it and it is working fine for me.
Doron
PostPosted: Fri May 29, 2020 3:12 am  (#3)
Thank you Pocholo one more time for your nice plug-ins. It works fine and quick. :tyspin :cool
PostPosted: Fri May 29, 2020 5:03 am  (#4)
I have a plugin that already does this, though without the text. It's easy to add text and this one can do non-square buttons as well.
Round_Web_2_0_Button_with_a_Metal_Ring_gimp_2_8.scm [15.1 KiB]
Downloaded 110 times
PostPosted: Fri May 29, 2020 5:42 am  (#5)
Congratulations to all :clap
but can I give an opinion despite my zero level?...I dare ;) : the clear oval above the letter is too sharp, too sharp ...IMHO
PostPosted: Fri May 29, 2020 5:52 am  (#6)
You can add blur or reduce opacity on that layer if you'd like.
PostPosted: Fri May 29, 2020 6:02 am  (#7)
Ok racer-x, I will try this afternoon. :)
