It is currently Sun Aug 30, 2026 11:38 am
 Post subject: Opus Vermiculatum Vitreum
PostPosted: Wed Jun 17, 2020 9:18 am  (#1)
After a long "incubation period", I'm ready to release my package for approximating a Roman style Mosaic with a glassy tiles look more than a stone tiles look.
It is composed by:
- 2 filters: the main operative filter which performs the transformation of a photo into a fake Roman mosaic and a front-end filter to select a preset on the base of the image type
- 11 presets (text files)
- 1 glass effects patterns set
- Rob Antonischen's script "chisel.scm" used inside the filter
- 1 tutorial
I want to thank warmly:
- Lyle, for his work on "inventing" how to use Gimp and G'mic for creating a Roman style mosaic effect (it's quite a lot of time that I created a Mosaic Lyle's Style filter....)
- Issabella (my precious friend), for the long and continuos support during all the phases of the project
 Post subject: Re: Opus Vermiculatum Vitreum
PostPosted: Wed Jun 17, 2020 9:24 am  (#2)
The filters:
DIEGO_MOSAIC_OpusVermiculatumVitreum.7z [8.85 KiB]
Downloaded 217 times
DIEGO_MOSAIC_OpusVermiculatumVitreumPreset.7z [2.58 KiB]
Downloaded 209 times
The presets folder:
MyOVVpresets.7z [549 Bytes]
Downloaded 211 times
PostPosted: Wed Jun 17, 2020 9:33 am  (#3)
The resources needed:
- RobA's script:
chisel.7z [2.68 KiB]
Downloaded 171 times
- SG patterns:
(in two filder for attachment limit)
part 1.7z [3.79 MiB]
Downloaded 273 times
part 2.7z [3.89 MiB]
Downloaded 253 times
PostPosted: Wed Jun 17, 2020 9:34 am  (#4)
The tutorial:
OPUS VERMICULATUM VITREUM TUTORIAL.pdf [1.13 MiB]
Downloaded 303 times
PostPosted: Wed Jun 17, 2020 9:36 am  (#5)
Note: this thread is for comments and critics (all very welcome) to the filters and resources.
For trial outcomes (also very welcome), use the corresponding thread in Gimp Art.
viewtopic.php?f=11&t=18468&start=0
Thanks!
PostPosted: Sun Jun 21, 2020 11:37 am  (#6)
Info:
in case you want to reduce the overload of your Gimp in a critical environment you may download only:
- the Main filter (OpusVermiculatumVitreum)
- RobA chisel.scm if not already in your system
When running the Main filter, for the parameter Glass Pattern choose option 0 (none)
