It is currently Mon Aug 31, 2026 3:03 am
 Post subject: Glass Frame Effects
PostPosted: Fri Aug 07, 2020 4:32 am  (#1)
Upon (indirect) request by Sallyanne, I post here the version I prepared some times ago for running under 2.10.
DIEGO_FRAMES_GlassFrameEffects210.7z [5.42 KiB]
Downloaded 401 times
In the meantime I also prepared a slightly modified version (suffixed 2020); use whichever you like better.
DIEGO_FRAMES_GlassFrameEffects2020.7z [5.63 KiB]
Downloaded 390 times
Remember that there are prerequisites, the same of the original version for 2.8:
Prerequisites:
- filter "python_layerfx_bevel_emboss"
- gimpressionist presets:
"PenDrawing" "Charcoal" "ColourPencil"
- patterns:
Glasstic_8 (no more for version 2020) MyGlass_11.jpg MyGlass_15.jpg MyGlass_17.jpg
Omg1_gray_64.pat
Omg1_gray_128.pat
 Post subject: Re: Glass Frame Effects
PostPosted: Fri Aug 07, 2020 4:52 am  (#2)
Thanks Diego for your update of you great filter. I did a few tests and both work great. :clap :tyspin
PostPosted: Fri Aug 07, 2020 9:00 am  (#3)
Thanks Dinasset. Good to hear you are well too.
Is there already some here?
PostPosted: Fri Aug 07, 2020 9:08 am  (#4)
Sallyanne, I have the pattern. :)
MyGlass_15.zip [388.69 KiB]
Downloaded 419 times
PostPosted: Fri Aug 07, 2020 9:45 am  (#5)
Hello, I am missing the plug-in for running "cartoons".
Does anyone have any idea which plug-in I need and
where I can get it.
DIEGO_FRAMES_GlassFrameEffects2020.py
Greetings from Germany.
PostPosted: Fri Aug 07, 2020 10:27 am  (#6)
Thank you Issabella. I did a quick one. Is there a place in resources where I can find the OMG patterns? I want to check that I have them before I try the other one.
PostPosted: Fri Aug 07, 2020 10:36 am  (#7)
Still using 2.10 vs
PostPosted: Fri Aug 07, 2020 10:59 am  (#8)
Omg1_gray_128.pat [64.04 KiB]
Downloaded 384 times
Omg1_gray_64.pat [16.04 KiB]
Downloaded 367 times
PostPosted: Fri Aug 07, 2020 11:08 am  (#9)
where I can get it.
It's included in Samj's package, copied here from there
cartoon.7z [17 KiB]
Downloaded 428 times
PostPosted: Fri Aug 07, 2020 11:16 am  (#10)
Thank you Dinasset
PostPosted: Fri Aug 07, 2020 11:53 am  (#11)
Here is my first one with that plugin
PostPosted: Fri Aug 07, 2020 1:40 pm  (#12)
Many options work better with light images, so i's cartoons.
PostPosted: Fri Aug 07, 2020 11:30 pm  (#13)
Homage a Ella.
PostPosted: Fri Aug 07, 2020 11:55 pm  (#14)
Lovely effects :) I was haveing trouble with a couple not finishing - my gimp stopped responding.
I will try them again now just incase my gimp need a 'rest'
PostPosted: Sat Aug 08, 2020 1:40 am  (#15)
Have done a couple more now including the ones that wouldn't finish for me yestday.
Does anyone get the error message that the image is too small though? I have with some. (image has to be at least 640x640) But it doesn't happen all the time with those same images.
PostPosted: Sat Aug 08, 2020 2:39 am  (#16)
Here is the puppy with gradient flare without the bevelImage
PostPosted: Sat Aug 08, 2020 3:03 am  (#17)
Does anyone have the "Charcoal" Preset
PostPosted: Sat Aug 08, 2020 3:08 am  (#18)
Just did a feathered selection on the puppy to give the illusion of fur going out in all directions, and to see if it could be done.
PostPosted: Sat Aug 08, 2020 3:09 am  (#19)
Hello "dinasset"
Many thanks for the link and
best regards from Germany - HARDY
PostPosted: Sat Aug 08, 2020 3:15 am  (#20)
Graechan, did you get the error - need 'My glass - 17' for Charcoal?
I haven't got it either.
