It is currently Thu Nov 26, 2026 7:45 am
 Post subject: Drawing - Style A
PostPosted: Wed Aug 26, 2020 3:09 am  (#1)
Having received a sort of "imprimatur" by OMG, Lyle and Issabella, I decided to release as a filter the last version of my experiment A in drawing.
It makes use of Gegl c2g (thanks to Kevin).
DIEGO_DRAWING_StyleA.7z [3.68 KiB]
Downloaded 432 times
Below the possible examples of outcome using this source image from Pixabay:
 Post subject: Re: Drawing - Style A
PostPosted: Wed Aug 26, 2020 3:11 am  (#2)
Outcomes using colours, in 3 slightly different possibilities (depending on pencil lead).
2020-08-26 09-53-48woman-5468716_1920 with a draw effect style A, option colours and pencil lead=HB (GEGL desat C2G).jpg
2020-08-26 09-53-48woman-5468716_1920 with a draw effect style A, option colours and pencil lead=HB (GEGL desat C2G).jpg [ 1.78 MiB | Viewed 8426 times ]
2020-08-26 09-54-27woman-5468716_1920 with a draw effect style A, option colours and pencil lead=HH (GEGL desat C2G).jpg
2020-08-26 09-54-27woman-5468716_1920 with a draw effect style A, option colours and pencil lead=HH (GEGL desat C2G).jpg [ 1.72 MiB | Viewed 8426 times ]
2020-08-26 09-55-12woman-5468716_1920 with a draw effect style A, option colours and pencil lead=BB (GEGL desat C2G).jpg
2020-08-26 09-55-12woman-5468716_1920 with a draw effect style A, option colours and pencil lead=BB (GEGL desat C2G).jpg [ 1.85 MiB | Viewed 8426 times ]
PostPosted: Wed Aug 26, 2020 3:13 am  (#3)
Now the outcomes using B&W, again in 3 slightly different possibilities (depending on pencil lead).
2020-08-26 09-57-45woman-5468716_1920 with a draw effect style A, option B&W and pencil lead=HB (GEGL desat C2G).jpg
2020-08-26 09-57-45woman-5468716_1920 with a draw effect style A, option B&W and pencil lead=HB (GEGL desat C2G).jpg [ 1.19 MiB | Viewed 8419 times ]
2020-08-26 09-58-35woman-5468716_1920 with a draw effect style A, option B&W and pencil lead=HH (GEGL desat C2G).jpg
2020-08-26 09-58-35woman-5468716_1920 with a draw effect style A, option B&W and pencil lead=HH (GEGL desat C2G).jpg [ 1.18 MiB | Viewed 8419 times ]
2020-08-26 09-59-28woman-5468716_1920 with a draw effect style A, option B&W and pencil lead=BB (GEGL desat C2G).jpg
2020-08-26 09-59-28woman-5468716_1920 with a draw effect style A, option B&W and pencil lead=BB (GEGL desat C2G).jpg [ 1.22 MiB | Viewed 8419 times ]
PostPosted: Wed Aug 26, 2020 3:18 am  (#4)
Tip.
The simplest and most effective customization can be obtained by playing with the mode and opacity of the first (top-down) visible layer ("Sketch applied").
Experimented alternative modes are:
- LINEAR_BURN
- OVERLAY
- DARKEN ONLY
but of course you may try any and see.
PostPosted: Wed Aug 26, 2020 9:45 am  (#5)
I'm impressed, once again. First with painting presets and now this.
PostPosted: Wed Aug 26, 2020 11:30 pm  (#6)
Thanks Mahvin, I appreciate your comment.
PostPosted: Mon Mar 08, 2021 2:22 pm  (#7)
Hello. Having a little trouble here. When I run Draw Effect Style A on an image.
1) I dont understand the value for the first box: is it literally add the values of height and width together ?
2) I get an error: LAYER_MODE_NORMAL is not defined. I also see this :
newBG.mode = LAYER_MODE_NORMAL in the error details.
I need to also say that I am using GIMP 2.8.22 : do I need 2.10 ?
Thank you
(LeftyLeo/James)
PostPosted: Mon Mar 08, 2021 4:39 pm  (#8)
Hi leftyleo, welcome to Gimp Chat. :)
About your questions, the first option is the size that the filter works.
Look at the shot where I try to explain the options.
Very very important it's you have G'MIC at the current version and actualized. The filter has a dependency on Gmic.
PostPosted: Mon Mar 08, 2021 7:28 pm  (#9)
Thank you
Do I need to use 2.10 ?
i tried to upgrade to 2.10 and I have to backtrack now before i re-try
looks like i have some other issues to clear up then i can retry
but I cant wait. I have outdoor photos that I would love to try some of these filters on to see what happens
--James
(LeftyLeo/James)
PostPosted: Tue Mar 09, 2021 3:22 am  (#10)
leftyleo wrote:
Thank you
--James
James, I forgot to say that All of his filters work ONLY on gimp 2.10
I hope you will share your results with us. Luck! :bigthup
PostPosted: Tue Feb 13, 2024 6:03 am  (#11)
PostPosted: Tue Feb 13, 2024 7:37 am  (#12)
A resurrection...
Thanks Jamal.
