It is currently Sun Aug 30, 2026 2:25 am
 Post subject: Drawing - Style B
PostPosted: Tue Sep 01, 2020 10:16 am  (#1)
After "trials and errors" I feel comfortable in releasing this second style for creating a drawing look to an image: my last trials have received a kind of "approval" by OMG, neurolurker, Ella and Issabella.
Main characteristics:
- allow a selection in input
- provides 3 different looks (at choice): gray, sepia, light colours
Because some filters used inside create different results depending on the image size, the filter uses internally a work image of a fixed size; this allows to get a uniform look independently from the source image.
Here the filter:
DIEGO_DRAWING_StyleB.7z [4.99 KiB]
Downloaded 262 times
 Post subject: Re: Drawing - Style B
PostPosted: Tue Sep 01, 2020 10:20 am  (#2)
As outcome examples I show:
- here the 3 possible looks without a selection
- on the next post the 3 possible looks having an input selection.
Source image from Deviant Art.
2020-09-01 16-55-41 de03anj-66d4e966-ebcc-49f8-9167-3daa1b4d9d9c, with gray look (full image).jpg
2020-09-01 16-55-41 de03anj-66d4e966-ebcc-49f8-9167-3daa1b4d9d9c, with gray look (full image).jpg [ 713.36 KiB | Viewed 3826 times ]
2020-09-01 16-58-03 de03anj-66d4e966-ebcc-49f8-9167-3daa1b4d9d9c, with sepia look (full image).jpg
2020-09-01 16-58-03 de03anj-66d4e966-ebcc-49f8-9167-3daa1b4d9d9c, with sepia look (full image).jpg [ 1.18 MiB | Viewed 3826 times ]
2020-09-01 16-59-13 de03anj-66d4e966-ebcc-49f8-9167-3daa1b4d9d9c, with light colours look (full image).jpg
2020-09-01 16-59-13 de03anj-66d4e966-ebcc-49f8-9167-3daa1b4d9d9c, with light colours look (full image).jpg [ 1010.97 KiB | Viewed 3826 times ]
PostPosted: Tue Sep 01, 2020 10:21 am  (#3)
2020-09-01 17-00-56 de03anj-66d4e966-ebcc-49f8-9167-3daa1b4d9d9c, with gray look (selected area)(BG blurred)(BG darkened).jpg
2020-09-01 17-00-56 de03anj-66d4e966-ebcc-49f8-9167-3daa1b4d9d9c, with gray look (selected area)(BG blurred)(BG darkened).jpg [ 452.21 KiB | Viewed 3825 times ]
2020-09-01 17-01-38 de03anj-66d4e966-ebcc-49f8-9167-3daa1b4d9d9c, with sepia look (selected area)(BG blurred)(BG darkened).jpg
2020-09-01 17-01-38 de03anj-66d4e966-ebcc-49f8-9167-3daa1b4d9d9c, with sepia look (selected area)(BG blurred)(BG darkened).jpg [ 689.04 KiB | Viewed 3825 times ]
2020-09-01 17-02-30 de03anj-66d4e966-ebcc-49f8-9167-3daa1b4d9d9c, with light colours look (selected area)(BG blurred)(BG darkened).jpg
2020-09-01 17-02-30 de03anj-66d4e966-ebcc-49f8-9167-3daa1b4d9d9c, with light colours look (selected area)(BG blurred)(BG darkened).jpg [ 584.2 KiB | Viewed 3825 times ]
