It is currently Sun Aug 30, 2026 11:52 pm
 Post subject: Custom Font Tools Release 12
PostPosted: Sun Sep 13, 2020 7:01 am  (#1)
Custom Font Tools R12 With Guide.zip [4.24 MiB]
Downloaded 350 times
 Post subject: Re: Custom Font Tools Release 12
PostPosted: Sun Sep 13, 2020 12:43 pm  (#2)
Your font plugins have been added to gimpscript.net. :bigthup
PostPosted: Sun Oct 04, 2020 4:24 pm  (#3)
Is this the most recent release or is there another one?
PostPosted: Sun Oct 04, 2020 4:30 pm  (#4)
Mahvin, with your gimpscripts site, I think there should be a search bar. That way users can find what they are looking for rather that looking through blog posts.
PostPosted: Sun Oct 04, 2020 4:44 pm  (#5)
There is. It's called The New Archive. Use Ctrl + F to "find" a script name.
And there is this on the sidebar, as well as the label menu at the bottom:
PostPosted: Sun Oct 04, 2020 4:49 pm  (#6)
If he's adding it to gimpscripts.net, it's the most recent release. When he updates it, he will most likely send me the update and I'll update the post with the newest release, instead of making a new separate post.
PostPosted: Sun Oct 04, 2020 6:00 pm  (#7)
Oh. I didn't check out the new archive. I was thinking that was a description of the site, which is why I didn't look. My fault. :)
PostPosted: Mon Oct 05, 2020 1:28 am  (#8)
:bigthup Just to be absolutely and definitely clear...
Release 12 (the latest) was released on September 13 2020 over on GimpLearn.
I release updates and additions in between new releases and then when I think there are enough changes (and when I can face updating the guide) I upload a new release to GimpLearn and add a post to GimpChat. Mahvin's GimpScripts is now on my list of sites to add releases to. :bigthup
