It is currently Mon Aug 31, 2026 1:48 am
 Post subject: pm_conbagui_welded_Text.py (Pocholo's way)
PostPosted: Sat Sep 19, 2020 2:27 pm  (#1)
I went to conbagui's tutorial found here: http://fav.me/d9vlx7y
and created this plugin that was givin a lot of users errors.
You need to download and install:
1. The font "parley bold" free font for personal use found here: https://www.whatfontis.com/FF_Parley-bold-Regular.font
Included in the folder:
1. "Metal with holes small.", a "Metal grid-1", a "Lava" and a "Rough wall" patterns
2. Three Sparks brushes - After you run the script; Use the Sparks brushes on the best
incandescence part of the text.
3. Layerfx.py plugin
Result
pm_conbagui_welded_Text.zip [1.8 MiB]
Downloaded 295 times
