It is currently Sun Aug 30, 2026 12:44 pm
 Post subject: Drawing - Style K
PostPosted: Fri Nov 20, 2020 8:26 am  (#1)
Both Issabella and myself have finished our tests.
So, here is the filter:
DIEGO_DRAWING_StyleK.7z [4.79 KiB]
Downloaded 315 times
GIMP plugin to create a drawing look using G'mic Engrave.
Inspired by a Nidhogg's tutorial posted on Gimpchat last year, but modified to create a Van Gogh style.
At the end of the process, the filter creates one or two (optional) layers, both masked:
- the first one created is a layer containing the yellow colour used by Van Gogh
- the second one created (thus, on top) is a layer containing the original image
If you choose to create them (options in the menu of the filter), the "yellow" layer is already active, because the mask is a gray copy of the original, the mode is set to LINEAR_LIGHT and the opacity to 50%. By this way the lightest zones of the standard outcome are "illuminated" by the Van Gogh yellow colour.
You may play as usual with opacity and mode, at your taste.
The "source" layer is created with a black mask, hence it's not active until the user paints over the mask with a light gray to determine the overlay of the source over the textured outcome.
 Post subject: Re: Drawing - Style K
PostPosted: Fri Nov 20, 2020 8:31 am  (#2)
First example:
2020-11-20 14-27-10taylor-hernandez-DLKR_x3T_7s-unsplash as a fake VanGogh engraved drawing (using Van Gogh weak effect).jpeg
2020-11-20 14-27-10taylor-hernandez-DLKR_x3T_7s-unsplash as a fake VanGogh engraved drawing (using Van Gogh weak effect).jpeg [ 1.29 MiB | Viewed 6777 times ]
-the Van Gogh effect applied is "weak"
-the yellow nuance has been applied, with a limited impact
-the face had not been "cleared" nor "smoothed" by overlaying the source
PostPosted: Fri Nov 20, 2020 8:39 am  (#3)
Second example (source from Deviant Art):
2020-11-20 14-35-02de6wa62-50b0ceb0-86c3-4a1d-93ef-8487e50d87a9-scaled4k as a fake VanGogh engraved drawing (using Van Gogh medium effect).jpeg
2020-11-20 14-35-02de6wa62-50b0ceb0-86c3-4a1d-93ef-8487e50d87a9-scaled4k as a fake VanGogh engraved drawing (using Van Gogh medium effect).jpeg [ 1.53 MiB | Viewed 6773 times ]
-the Van Gogh effect applied is "medium"
You will find much better examples by Issabella in the thread used for Experimenting this style
