It is currently Mon Aug 31, 2026 1:06 am
 Post subject: Drawing - Style G (v.2)
PostPosted: Tue Jan 19, 2021 4:51 am  (#1)
The original Style G has been abandoned due to problems with Gimp aborting as well as with texture filling prfecision.
This version 2 uses a completely different procedure.
After experiments done in the past days, it's ready to be released (no pending errors or requests for en enhancements)
Here the Style G plug-in (version 2 to keep track that there was an original different process)
DIEGO_DRAWING_StyleG2.7z [3.38 KiB]
Downloaded 270 times
 Post subject: Re: Drawing - Style G (v.2)
PostPosted: Tue Jan 19, 2021 4:53 am  (#2)
Here 3 outcomes using the same source, showing the use of the option for the lines look.
Obviously with this subject, the best option is "curved lines", the other two options ("horizontal" and "vertical" are more suitable for landscapes or cityscapes having respectively an horizontal or vertical shape)
2021-01-19 10-35-56 pexels-andrea-piacquadio-712521 stroked using stencil, neon stroked using stencil, neon, lines vertical, gray-copy mask.jpeg
2021-01-19 10-35-56 pexels-andrea-piacquadio-712521 stroked using stencil, neon stroked using stencil, neon, lines vertical, gray-copy mask.jpeg [ 895.43 KiB | Viewed 7196 times ]
2021-01-19 10-34-09 pexels-andrea-piacquadio-712521 stroked using stencil, neon stroked using stencil, neon, lines horizontal, gray-copy mask.jpeg
2021-01-19 10-34-09 pexels-andrea-piacquadio-712521 stroked using stencil, neon stroked using stencil, neon, lines horizontal, gray-copy mask.jpeg [ 958.57 KiB | Viewed 7196 times ]
2021-01-19 10-32-35 pexels-andrea-piacquadio-712521 stroked using stencil, neon stroked using stencil, neon, lines curved, gray-copy mask.jpeg
2021-01-19 10-32-35 pexels-andrea-piacquadio-712521 stroked using stencil, neon stroked using stencil, neon, lines curved, gray-copy mask.jpeg [ 1.13 MiB | Viewed 7196 times ]
PostPosted: Tue Jan 19, 2021 6:48 am  (#3)
:wvy dinasset, I'll try it. :)
PostPosted: Tue Jan 19, 2021 11:40 am  (#4)
PostPosted: Wed Jan 20, 2021 4:31 am  (#5)
:wvy
PostPosted: Wed Jan 20, 2021 6:09 am  (#6)
Thanks, level_0, you found a good image to apply "horizontal" strokes.
Great.
PostPosted: Wed Jan 20, 2021 9:13 pm  (#7)
level_0 wrote:
Well, it is so fabulous though. I want to know more about the effect.
PostPosted: Wed Jan 20, 2021 9:15 pm  (#8)
level_0 wrote:
:wvy
Superb to look at! How did you do this?
PostPosted: Thu Jan 21, 2021 2:46 am  (#9)
Just try yourself downloading the filter on post#1
