It is currently Mon Aug 31, 2026 1:04 am
 Post subject: Drawing - Style M
PostPosted: Tue Jan 19, 2021 1:17 pm  (#1)
No errors detected so far, no requests for enhancements, hence time to publish also this one.
It has two main components:
- a rewriting of RobA Border Inward Repeat (embedded)
- a top G'mic texturing effect (user's choice among 3)
Here the filter:
DIEGO_DRAWING_StyleM.7z [6.4 KiB]
Downloaded 270 times
 Post subject: Re: Drawing - Style M
PostPosted: Tue Jan 19, 2021 1:20 pm  (#2)
Here 3 outcomes, one for each top over G'mic texture effect, using same source image.
2021-01-19 18-37-22 pexels-mentatdgt-1024311_square, as a drawing using 12 colours (G'mic seamless turbo),BG=original (gray copy mask).jpeg
2021-01-19 18-37-22 pexels-mentatdgt-1024311_square, as a drawing using 12 colours (G'mic seamless turbo),BG=original (gray copy mask).jpeg [ 4.32 MiB | Viewed 8163 times ]
2021-01-19 18-35-41 pexels-mentatdgt-1024311_square, as a drawing using 12 colours (G'mic whirls),BG=original (gray copy mask).jpeg
2021-01-19 18-35-41 pexels-mentatdgt-1024311_square, as a drawing using 12 colours (G'mic whirls),BG=original (gray copy mask).jpeg [ 2.64 MiB | Viewed 8163 times ]
2021-01-19 18-32-53 pexels-mentatdgt-1024311_square, as a drawing using 12 colours (G'mic turbo halftone),BG=original (gray copy mask).jpeg
2021-01-19 18-32-53 pexels-mentatdgt-1024311_square, as a drawing using 12 colours (G'mic turbo halftone),BG=original (gray copy mask).jpeg [ 4.69 MiB | Viewed 8163 times ]
PostPosted: Thu Jan 21, 2021 5:00 am  (#3)
dinasset :wvy
I got an error message:
PostPosted: Thu Jan 21, 2021 5:04 am  (#4)
Please send me the source image so that I can reproduce and solve the issue, tanks.
PostPosted: Thu Jan 21, 2021 5:26 am  (#5)
it's this one but resized to: 1200x900
PostPosted: Thu Jan 21, 2021 5:27 am  (#6)
Thanks, I will check and fix.
PostPosted: Thu Jan 21, 2021 5:57 am  (#7)
I could not reproduce the error, unfortunately.
But just thinking at a possible cause, I introduced a fix which COULD avoid the problem.
I attach here the amended version, please continue your tests using this one:
Attachment removed, it didn't solve the problem, look at the new attachment a few posts below
Let me know.
PostPosted: Thu Jan 21, 2021 6:42 am  (#8)
Ok, I'll start over with the new one but I have to go cook first ... ;)
I didn't get the error every time so first result:
and after with Graphic boost:
PostPosted: Thu Jan 21, 2021 6:52 am  (#9)
Thanks !
Very nice ourcomes (the third one is wonderful), .... and have a good lunch!
PostPosted: Thu Jan 21, 2021 9:14 am  (#10)
I did 2 tries without problem then again this:
PostPosted: Thu Jan 21, 2021 10:07 am  (#11)
Thanks, I'll check.
PostPosted: Thu Jan 21, 2021 10:18 am  (#12)
I applied another fix.
Here the amended version:
DIEGO_DRAWING_StyleM0.7z [6.42 KiB]
Downloaded 163 times
Could you replace the previous one and try again?
Sorry to give you the annoying task of double-checking my fixes, but it's because I could not reproduce the error, hence I have to rely on your tests.
Many thanks in advance
PostPosted: Fri Jan 22, 2021 3:06 am  (#13)
Which version of G'mic do you have, level_0?
PostPosted: Fri Jan 22, 2021 4:01 am  (#14)
dinasset,Gmic 2.9.4
PostPosted: Fri Jan 22, 2021 6:05 am  (#15)
In case you encounter again problems after my second fix, it could be the case to upgrade to 2.9.5
PostPosted: Fri Jan 22, 2021 9:27 am  (#16)
dinasset,yesterday no problem with the last version,thank you :) (I did not put my attemps because not to my taste. ;) ,I will start again)
PostPosted: Fri Jan 22, 2021 9:31 am  (#17)
Thanks for the info!
Maybe the 2 fixes solved anyhow the problem; good.
