It is currently Mon Aug 31, 2026 7:55 am
 Post subject: pm_carved_plastic_or_chrome_text.py
PostPosted: Thu Jan 21, 2021 10:57 pm  (#1)
Hi everyone! 2020 has been a rough year for everyone. One way for some folk and another for others. I lost my part-time job due to my disability and my age when the "Covid-19" hit my area. A lot of my family had have tested positive, but only one we lost. I'm sure, I can relate with somebody here. I for sometime, was so depressed that I did not wanted to write anymore codes and make GIMP plugins. But "We are down, but not out of the fight". And I am darn sure not going to stop "GIMPING".
So here is my latest plugin. Please leave comment!
You have a choice to create the text on a Plastic effect
Or have a choice to create the text on a Chrome effect
pm_carved_plastic_or_chrome_text.zip [1.45 MiB]
Downloaded 192 times
 Post subject: Re: pm_carved_plastic_or_chrome_text.py
PostPosted: Fri Jan 22, 2021 1:26 am  (#2)
Pocholo, I am very sorry that your family has lost someone to Covid. Please stay safe, be careful. I can't think of a better way to use my "free" time than to play with GIMP. Keep writing your scripts! I will try yours soon.
PostPosted: Fri Jan 22, 2021 1:40 am  (#3)
I'm very sorry too, Pocholo.
PostPosted: Fri Jan 22, 2021 1:47 am  (#4)
Thank you for letting us know again. I had indeed missed you for a while. I hope it all gets a bit more positive for you now, but for now thanks in advance for sharing your plugin.
PostPosted: Fri Jan 22, 2021 2:27 am  (#5)
Sorry to hear of your loss...on a good note, we have been fortunate in our part of the world to be relatively covid free..
I like the look of your chrome effect and will be adding it to my library of things GIMP. Thank You!
PostPosted: Fri Jan 22, 2021 4:10 am  (#6)
Pocholo, we are all with you in this sad time.
I will try your plugin but I saw that you had attached an FX layer.Is it essential or the one from Mareroq (August 2020_281 KB) is suitable?
PostPosted: Fri Jan 22, 2021 10:19 am  (#7)
Thank you everyone for your kind comments. You don't know how uplifting are your kind words! :thanku
PostPosted: Fri Jan 22, 2021 10:22 am  (#8)
Yes, I believe it should work with the updated Layerfx version you have installed.
PostPosted: Fri Jan 22, 2021 11:42 am  (#9)
Pocholo, I've just read about your loss. I'm sorry. May you find comfort soon by remembering the best of your loved one.
I'll try your new plug-in. Thank you so much.
PostPosted: Fri Jan 22, 2021 12:26 pm  (#10)
firsts attemps :)
Image Image
PostPosted: Fri Jan 22, 2021 12:30 pm  (#11)
I like the result. Thank you so much Pocholo. It works great!
If it isn't too much pain, could you please set the plug at the possibility to get all of the layers? no combined.
Thank you.
PostPosted: Fri Jan 22, 2021 2:26 pm  (#12)
@ level_0: Nice outcome, thank you for testing the plugin!
@ Issabella: Thank you, I'm glad you like it. After the plugin finished the process, just click undo twice and it will give you all the layers it created.
PostPosted: Sat Jan 23, 2021 2:20 am  (#13)
Thanks Pocholo. It works as you say. Great! :bigthup
PostPosted: Sat Jan 23, 2021 12:02 pm  (#14)
Pocholo, I have old tutorials kept, if you want to get some of them, I'll look for them and if I have it, I'll post them. :bigthup
PostPosted: Sat Jan 23, 2021 12:56 pm  (#15)
Issabella, go ahead and post them. Do you want me to create a plugin from you tuts in particular?
PostPosted: Sat Jan 23, 2021 2:04 pm  (#16)
I post some of them if they are possible to do in plug-ins.
tut3.zip [4.05 MiB]
Downloaded 155 times
tuts2.zip [4.4 MiB]
Downloaded 159 times
tuts1.zip [4.13 MiB]
Downloaded 211 times
PostPosted: Sat Jan 23, 2021 2:05 pm  (#17)
EXPOSED Plastic Text tutorial.zip [4.38 MiB]
Downloaded 236 times
PostPosted: Sat Jan 23, 2021 11:44 pm  (#18)
I'll try, thank you for sharing. :)
PostPosted: Wed Feb 24, 2021 11:39 pm  (#19)
In case you missed the PM I sent you.
Hi Issabella! This tutorial that you post me to create a plugin "How to create a Paper Heart Valentine Card", did not have a folder.
I'm missing:
1. Paths, two of them "Heart and Hart line".
2. The brush "Rose brush23".
3. The Dynamics brush "Fade to Fade"
This is a nice tutorial, can you please send those three files so I can write a plugin?Thank you in advance.
PostPosted: Thu Feb 25, 2021 12:38 am  (#20)
Pocholo, I found these missing items, but the path... I don't know where I should look for it, please can you guide me to check it?
2 items.zip [28.15 KiB]
Downloaded 78 times
