It is currently Sat Aug 29, 2026 8:53 pm
 Post subject: Help with Resynthesizer
PostPosted: Mon Feb 01, 2021 5:14 pm  (#1)
Hello! I need some help with the resynthesizer. I'm trying to heal an image but I keep getting an error. I've already downloaded the resynthesizer plugin, redownloaded it and GIMP multiple times. I've also seen if I had any double programs, which I don't.
These are the messages:
GIMP Message
Plug-in crashed: "resynthesizer - Copy.exe"
(C:\Users\rosie\AppData\Roaming\GIMP\2.10\plug-ins\resynthesizer.exe)
The dying plug-in may have messed up GIMP's internal state. You may want to save your images and restart GIMP to be on the safe side.
GIMP Message
Calling error for procedure 'plug-in-resynthesizer':
Procedure 'plug-in-resynthesizer' returned no return values
An error occurred running python_fu_heal_selection
RuntimeError: Procedure 'plug-in-resynthesizer' returned no return values
+More Information
File "C:\Program Files\GIMP 2\lib\gimp\2.0\python/gimpfu.py", line 740, in response
File "C:\Program Files\GIMP 2\lib\gimp\2.0\python/gimpfu.py", line 361, in run_script
File "C:\Users\rosie\AppData\Roaming\GIMP\2.10\plug-ins\plugin-heal-selection.py", line 148, in heal_selection
pdb.plug_in_resynthesizer(timg, tdrawable, 0,0, useBorder, work_drawable.ID, -1, -1, 0.0, 0.117, 16, 500)
What should I do? I need this to work for my project. :gaah :gaah
 Post subject: Re: Help with Resynthesizer
PostPosted: Mon Feb 01, 2021 7:27 pm  (#2)
Did you downloaded the plugin from here? https://www.gimpscripts.net/search?q=resynthesizer
This is the one for Windows 10 64bit.
If not delete the one you have in your computer and download the one mention in the link above.
PostPosted: Wed Feb 03, 2021 12:28 pm  (#3)
No, my laptop is a 32-bit Windows 10. Acer Aspire Switch 5 I think. Had it for about 5-6 years.
PostPosted: Wed Feb 03, 2021 1:10 pm  (#4)
Then you need a 32 bit windows version. Attached. Unzip, put the four files
plugin-heal-transparency.py
resynthesizer.exe
resynthesizer-gui.exe
in your user profile C:\Users\My_username\AppData\Roaming\GIMP\2.10\plug-ins
resynthesizer-32-bit-windows.zip [32.52 KiB]
Downloaded 199 times
