It is currently Sat Aug 29, 2026 8:53 pm
 Post subject: Drawing - Style O
PostPosted: Sun Feb 07, 2021 7:01 am  (#1)
Time to release it to the GC public.
It makes use of G'mic Doodle (hence it's a bit slow) as well as of G'mic Color Abstract (hence producing outcomes which may or may not be pleasant, depending on the user's acceptance of "strange" colours).
Here the filter:
DIEGO_DRAWING_StyleO.7z [3.63 KiB]
Downloaded 195 times
Here one outcome:
2021-02-07 12-36-01 pexels-christian-kunz-2499271, with a sort of abstract look.jpeg
2021-02-07 12-36-01 pexels-christian-kunz-2499271, with a sort of abstract look.jpeg [ 1.01 MiB | Viewed 3472 times ]
Many others have been published on the related thread "Experimenting..."
 Post subject: Re: Drawing - Style O
PostPosted: Sun Feb 07, 2021 9:28 am  (#2)
dinasset, :wvy does it replace the "DIEGO_DRAWING_ExperimentingO2"?
PostPosted: Sun Feb 07, 2021 10:26 am  (#3)
Yes, it's its official release.
Everytime I start with "Experimenting..." then, after tests, I release is as Style.
PostPosted: Sun Feb 07, 2021 11:00 am  (#4)
dinasset,my question was poorly worded.
Is it just the name that has changed?
PostPosted: Sun Feb 07, 2021 11:40 am  (#5)
A part from some coding cleaning, yes.
