It is currently Mon Aug 31, 2026 7:25 am
 Post subject: Script-fu interactive UI window - font size and spacing
PostPosted: Sun Feb 21, 2021 9:57 am  (#1)
Hi,
Anyone know how to change the appearance of the fonts and spacing in the UI for script-fu?
 Post subject: Re: Script-fu interactive UI window - font size and spacing
PostPosted: Sun Feb 21, 2021 1:31 pm  (#2)
Likely the same as some other font used in the Gimp UI... That would mean it is set by the theme.
PostPosted: Sun Feb 21, 2021 1:52 pm  (#3)
You'd think so, it does, but is still relatively bigger than the rest of the menu fonts, and doubly spaced.
PostPosted: Mon Feb 22, 2021 8:28 am  (#4)
It's the same size as the menu items, at least here on Windows:
It's the text on the dockable dialogs that is reduced from the default font-size by this line in the gtkrc file for the theme:
  GimpDock::font-scale = 0.8333
At present I haven't found a way to alter the theme of an auto generated dialog.
Kevin
PostPosted: Mon Feb 22, 2021 1:32 pm  (#5)
Thanks for the info, on linux mint here.
