It is currently Mon Aug 31, 2026 9:11 am
 Post subject: Create a Paper Heart valentine plugin (updated)
PostPosted: Thu Feb 25, 2021 11:48 am  (#1)
Hi! This is one of varios request that our friend Issabella requested out of tutorials made. Thank you for the tutorial Issabella.
**Please comment. If I left out anything in the folder, let me know.
** Can scale the Image from 1000 px square size to 2000 px square size
Version2
create_paper_heart_valentie_cardV2.zip [346.45 KiB]
Downloaded 145 times
create_paper_heart_valentie_card.zip [346.37 KiB]
Downloaded 114 times
 Post subject: Re: Create a Paper Heart valentine plugin (Issabella request)
PostPosted: Fri Feb 26, 2021 1:16 am  (#2)
Pocholo, thank you so much for your new design in plug-in. It is great and runs quickly, too. :clap
I know that the design of the tut is just as you did it. It's perfect! But I think that the decorative rose is too big and placed in the center covers too much space in the photo.
I never saw it practical when I did the tutorial if one wants to set a loved photo.
I would prefer if the rose was smaller and placed a bit more to the right if it was possible. Please, forget it if it is too much hard work.
PostPosted: Fri Feb 26, 2021 2:33 am  (#3)
Issabella thank you for the feedback. :hi5 I will fix it by tomorrow.
PostPosted: Fri Feb 26, 2021 4:00 am  (#4)
Thank you very much. :tyspin
PostPosted: Fri Feb 26, 2021 10:55 am  (#5)
Hi Issabella! The reason why the flower was more toward the center was that I did not expect anybody to increase the size of the Canvas. I had the brush in certain location in the heart and once you increase the size square to 900 x x900 px the brush was in the same location and it looks line it moves.
Look for the v2 in the inicial post.
The fix is to have an option to incrase the size of the image. you can make the size from 1000 px to 2000px. I also decrease the size of the flower.
 Post subject: Re: Create a Paper Heart valentine plugin (updated)
PostPosted: Fri Feb 26, 2021 11:53 am  (#6)
Pocholo, Thanks again for your effort but it doesn't look correct and I get everything displaced.
I really think that it's easier for the user to place the rose where he/she wishes.
Please, forget what I said. I feel bad after you have worked so hard. Sorry. :oops:
I post the result I got with a 1200 canvas.
After that, I tried it with your first version at 1600 px. I set the rose a bit more to right. and Great.
So, I think that your first version is the right one. :clap
Thanks a lot :tyspin
PostPosted: Fri Feb 26, 2021 3:23 pm  (#7)
Don't worry about if you are trying to tell me there is something wrong, this is part of learning.
*OK. In the "Read me please" file, I instructed to open a square 1600 x 1600 px New Image or project. From there when open the plugin you can change the Image size from 1000 square px - 2000 square px.
If you start bigger or smaller than 1600 px it's going to place the Rose in different part where it was meant to be. I hope I explained it well.
PostPosted: Sat Feb 27, 2021 2:55 am  (#8)
You are right, sorry. I misunderstood about sizes.
It's perfect and version 2 is great. It works awesome! Thank you so much Pocholo for your fine job. :clap :paint :tyspin
PostPosted: Sat Feb 27, 2021 4:07 pm  (#9)
What is the difference between version 1 and version 2?
PostPosted: Sat Feb 27, 2021 11:23 pm  (#10)
Hi Mackenzie! The answer to that is, I made the first version with one size only. You can open a blank image 1600 x 1600 px and don have the option to resize it.
With version 2, you have to open a blank image 1600 x 1600 px, but you have the option to resize it, from 1000 - 2000 px.
PostPosted: Sun Feb 28, 2021 1:26 am  (#11)
Thanks Pocholo! :)
