It is currently Mon Aug 31, 2026 9:55 am
 Post subject: Drawing - Style Z
PostPosted: Sun Feb 28, 2021 5:35 am  (#1)
Alphabet completed!
Release of Style Z.
It creates the drawing making use of G'mic Osgood plug-in and a bit of Gimp Plasma.
It could be a bit slow.
Here the filter:
DIEGO_DRAWING_StyleZ.7z [3.5 KiB]
Downloaded 186 times
Here some outcomes:
2021-02-28 11-21-25 pexels-anna-tarazevich-6712288 stroked by G'mic Osgood plug-in.jpeg
2021-02-28 11-21-25 pexels-anna-tarazevich-6712288 stroked by G'mic Osgood plug-in.jpeg [ 643.63 KiB | Viewed 3229 times ]
2021-02-28 11-23-30 pexels-anna-tarazevich-6412290 stroked by G'mic Osgood plug-in.jpeg
2021-02-28 11-23-30 pexels-anna-tarazevich-6412290 stroked by G'mic Osgood plug-in.jpeg [ 720.97 KiB | Viewed 3229 times ]
You may play with the mask to smooth the effects at your taste.
Otherwise you may limit the source images to landscapes etc, not people
 Post subject: Re: Drawing - Style Z
PostPosted: Sun Feb 28, 2021 10:23 am  (#2)
Alphabet completed!
dinasset,we have to celebrate!
Edit: styles A, B, C ... I don't see them on GC
PostPosted: Sun Feb 28, 2021 1:01 pm  (#3)
Alphabet completed!
I have not been following here for a while. But congratulations on your tremendous work, Diego :ffy
When I have more time I will take a look at all the filters.
And for level_0 ...
viewtopic.php?f=9&t=18702
viewtopic.php?f=9&t=18735
viewtopic.php?f=9&t=18827
viewtopic.php?f=9&t=18808
:wvy
PostPosted: Mon Mar 01, 2021 12:24 am  (#4)
level_0 wrote:
Alphabet completed!
Cheers !
Cin cin !
Prosit !
Thanks Level_0!
PostPosted: Tue Mar 02, 2021 2:40 am  (#5)
Ella wrote:
And for level_0 ...
viewtopic.php?f=9&t=18808 :wvy
Merci Ella Image
PostPosted: Tue Mar 02, 2021 3:13 am  (#6)
I would like to start the alphabet over again, but I have not found the G (or G2) nor the H ..I,J.............
PostPosted: Tue Mar 02, 2021 3:50 am  (#7)
Instead of giving you the "fishes", I tell you "fishing" (as Chinese people say)
Do advanced search in Gimp using the parameters as below:
In case ou still have problems, I will post the links
PostPosted: Tue Mar 02, 2021 4:55 am  (#8)
but this is what I did only the plugins do not appear for download and I read all the example pages:
http://gimpchat.com/viewtopic.php?p=257625#p257625
http://gimpchat.com/viewtopic.php?p=257647#p257647
http://gimpchat.com/viewtopic.php?p=257960#p257960
http://gimpchat.com/viewtopic.php?p=257499#p257499
PostPosted: Tue Mar 02, 2021 5:14 am  (#9)
Congratulations Dinasset on your perseverance :clap
PostPosted: Tue Mar 02, 2021 5:15 am  (#10)
level_0 wrote:
did you use all the parameters I showed you?
PostPosted: Tue Mar 02, 2021 5:24 am  (#11)
You should get 3 pages, I show you here (incomplete)
PostPosted: Tue Mar 02, 2021 5:25 am  (#12)
Do you get these pages or different ones?
Check again the parameters.
PostPosted: Tue Mar 02, 2021 5:32 am  (#13)
please check
it's foundamental you select only the section GimpScripts&Plugins and first post
PostPosted: Tue Mar 02, 2021 5:37 am  (#14)
It would be nice if you can get what I hope, but I do not want to bother you long.
I can post again all those you miss, just tell me which ones.
