It is currently Wed Sep 02, 2026 8:30 pm
 Post subject: Links to my Alphabet
PostPosted: Tue Mar 02, 2021 8:37 am  (#1)
in descending order:
Z viewtopic.php?f=9&t=19197&hilit=Drawing+Style
Y viewtopic.php?f=9&t=19196&hilit=Drawing+Style
X viewtopic.php?f=9&t=19195&hilit=Drawing+Style
W viewtopic.php?f=9&t=19194&hilit=Drawing+Style
V viewtopic.php?f=9&t=19192&hilit=Drawing+Style
U viewtopic.php?f=9&t=19188&hilit=Drawing+Style
T viewtopic.php?f=9&t=19180&hilit=Drawing+Style
S viewtopic.php?f=9&t=19179&hilit=Drawing+Style
R viewtopic.php?f=9&t=19178&hilit=Drawing+Style
Q viewtopic.php?f=9&t=19136&hilit=Drawing+Style
P viewtopic.php?f=9&t=19133&hilit=Drawing+Style
O viewtopic.php?f=9&t=19132&hilit=Drawing+Style
N viewtopic.php?f=9&t=19070&hilit=Drawing+Style
M viewtopic.php?f=9&t=19068&hilit=Drawing+Style
L viewtopic.php?f=9&t=18968&hilit=Drawing+Style
K viewtopic.php?f=9&t=18933&hilit=Drawing+Style
J viewtopic.php?f=9&t=18909&hilit=Drawing+Style
I viewtopic.php?f=9&t=18996&hilit=Drawing+Style
H viewtopic.php?f=9&t=18880&hilit=Drawing+Style
G viewtopic.php?f=9&t=19066&hilit=Drawing+Style
F viewtopic.php?f=9&t=18986&hilit=Drawing+Style
E viewtopic.php?f=9&t=18846&hilit=Drawing+Style
D viewtopic.php?f=9&t=18808&hilit=Drawing+Style
C viewtopic.php?f=9&t=18827&hilit=Drawing+Style
B viewtopic.php?f=9&t=18735&hilit=Drawing+Style
A viewtopic.php?f=9&t=18702&hilit=Drawing+Style
 Post subject: Re: Links to my Alphabet
PostPosted: Tue Mar 02, 2021 8:47 am  (#2)
And some are on GimpScripts.net as well, just use New Archive page and Ctrl + F and type in Diego.
PostPosted: Tue Mar 02, 2021 12:54 pm  (#3)
I have thought it would be useful to have a guide to the whole styles Diego has created.
I post them so that anybody has their style election a bit easier.
Guide Look To Choose Effect A to I.zip [5.31 MiB]
Downloaded 131 times
Guide Look To Choose Effect J to O.zip [4.31 MiB]
Downloaded 144 times
PostPosted: Tue Mar 02, 2021 12:55 pm  (#4)
Guide Look To Choose Effect P to U.zip [4.15 MiB]
Downloaded 156 times
Guide Look To Choose Effect V to Z.zip [2.65 MiB]
Downloaded 145 times
PostPosted: Tue Mar 02, 2021 12:57 pm  (#5)
A_B_C Styles.zip [1.8 MiB]
Downloaded 163 times
D_E_F Styles.zip [1.39 MiB]
Downloaded 186 times
G_H_I Styles.rar [129.88 KiB]
Downloaded 136 times
PostPosted: Tue Mar 02, 2021 12:58 pm  (#6)
J_K_L_Styles.zip [1.97 MiB]
Downloaded 143 times
M_N_O Styles.zip [2.07 MiB]
Downloaded 130 times
P_Q_R_Styles.zip [2.05 MiB]
Downloaded 169 times
PostPosted: Tue Mar 02, 2021 12:59 pm  (#7)
S_T_U Styles.zip [1.99 MiB]
Downloaded 58278 times
V_W_X Styles.zip [1.9 MiB]
Downloaded 146 times
Y_Z Styles.zip [753.36 KiB]
Downloaded 122 times
PostPosted: Tue Mar 02, 2021 1:28 pm  (#8)
Excellent Issabella.
Maybe you can group anything into one tutorial (is it possible? IDK)
PostPosted: Tue Mar 02, 2021 3:06 pm  (#9)
Thank you dinasset for your patience ...
Thank you Mahvin for this indication
Thanks Issabella for these guides.
PostPosted: Wed Mar 03, 2021 10:30 pm  (#10)
Not all of them work. I posted a comment here: viewtopic.php?f=11&t=19175&start=120 (page 13, post 125).
PostPosted: Wed Mar 03, 2021 11:57 pm  (#11)
If all errors you encounter are ALWAYS related to a G'MIC command:
- which version of G'MIC do you have?
I run G'mic 2.9.5_pref#210127
PostPosted: Thu Mar 04, 2021 12:18 am  (#12)
I have the current stable version 2.9.6
PostPosted: Thu Mar 04, 2021 12:20 am  (#13)
I will move to .6 and try.
I'll let you know.
PostPosted: Thu Mar 04, 2021 12:24 am  (#14)
I'll let you know.
Okay.
PostPosted: Thu Mar 04, 2021 12:36 am  (#15)
OK, done.
The problems occur if you do not update (internet) G'mic filters after the installation of the new release.
The simple installation sets active only the basic (402) filters, the subsequent internet update will add all the non standard filters, so at the end you have 564 filters, included those my filters use.
Just update and try.
PostPosted: Fri Mar 05, 2021 4:51 am  (#16)
Hello Issabella (Isabel? hi hi)
I came across this thread and got interested.
It looks like that you created several different pictures out of ONE using Diego's addons, right?
The zip files do not contain the originals, only the results ?
I tried two of Diego's plugins (are visible to be chosen), but no result or got error messages
Trying to understand, I executed begin commands in the Gimp Python Konsole, but yet not with succes, partially understood
only.
Is my attachment suitable for (one or more of the Diego plugins?)
PostPosted: Fri Mar 05, 2021 8:55 am  (#17)
PKHG, you are right.
Diego created the whole effects one for each letter of the abecedary.
You can get all of them just in this thread post number 1
You can install them into your plug-ins filter in Preferences.
The filters were release bit a bit so Diego set in the first post the link for each one.
My contribution only was to create a PDF showing the results / effects that each filter provides.
This was because it's difficult to remember so many effects. The guide helps to see it at once.
About the errors windows, it is very probable that you should actualize G'MIC before running the filters.
Anyway, if you have more problems, Diego will be able to help you more specifically.
The whole PDF with not split parts is this:
https://wetransfer.com/downloads/e21f05 ... 050/f7c685
