It is currently Mon Sep 07, 2026 12:43 am
 Post subject: ParticlesThuSphereMap
PostPosted: Mon Mar 22, 2021 6:03 am  (#1)
I think the testing period could be considered finished: no errors (and no enhancements ideas).
I asked my three very kind co-testers and they agreed.
So here the filter at its final stage:
DIEGO_DECOR_ParticlesThruSphereMap.7z [4.26 KiB]
Downloaded 198 times
here only one example.
2021-03-22 11-30-071b2954309ffdf341df3f49b9fcfceac9-dcj4c3z with a particles effect using Map Object (Sphere).jpeg
2021-03-22 11-30-071b2954309ffdf341df3f49b9fcfceac9-dcj4c3z with a particles effect using Map Object (Sphere).jpeg [ 626.65 KiB | Viewed 2612 times ]
Other outcomes from all those who like to use it can be posted in the corresponding thread used during the test period viewtopic.php?f=11&t=19238.
But, if you find errors or like to suggest enhancements, you may post them here.
Many thanks to Issabella, Mackenzieh and Pat for their support in the testing phase.
 Post subject: Re: ParticlesThuSphereMap
PostPosted: Mon Mar 22, 2021 3:54 pm  (#2)
I believe it is customary in your country to kiss each cheek in gratitude but as we are miles apart, I will just give you a high 5 smiley. :hi5 Thank you very much. I'm going to use this filter well and I will post some of the results. :)
PostPosted: Mon Mar 22, 2021 6:26 pm  (#3)
Hello_
I love how this looks and seem have a problem here . I am probably overlooking something very
basic. The plug-in crashes when i run it with the default settings and i get a message about " plug-in-map-object' returned no return values .
Is there an image requirement to begin with or cad this be applied to a photo ? perhaps that is my problem?
I am on GIMP 2.10 / Linux Mint (i need to make a signature so i dont have to add this)
(LeftyLeo/James)
PostPosted: Mon Mar 22, 2021 11:32 pm  (#4)
Thanks Erisian.
Waiting for your plays.
PostPosted: Mon Mar 22, 2021 11:33 pm  (#5)
leftyleo wrote:
Hello_
If not private, could you post your image so that I can try to reproduce your error?
Edit: obviously my request does not make sense if it happens to you whichever image yhou use.
