It is currently Mon Sep 07, 2026 7:24 am
 Post subject: mhkabifubuki.scm
PostPosted: Mon Mar 22, 2021 4:43 pm  (#1)
https://kikidide.yuki-mura.net/GIMP/engimp.htm
I found this scm file mhkabifubuki..on this site.
I don't think I've seen it before. In Gimp 2.8 it works fine .. unfortunately not in 2.10 (Windows). Does it make sense to look at it.
2028_mhkamifubuki.scm [5.16 KiB]
Downloaded 165 times
 Post subject: Re: mhkabifubuki.scm
PostPosted: Mon Mar 22, 2021 5:07 pm  (#2)
It works in 2.10, I see you already tried it. It's Japanese, and Kamifuku means Confetti.
PostPosted: Mon Mar 22, 2021 11:40 pm  (#3)
Pocholo, thanks for the translation and Jappaloe63 is correct, this script does not work with Windows 10, Gimp 2.10.22. When trying to run it, I get this error:
PostPosted: Tue Mar 23, 2021 1:29 am  (#4)
I translated this script in English just leaving the Japanese title and I added English title.
I also constantized it to work for GIMP 2.10
script-fu-22mhkamifubuki-Confetti-text-effect.zip [1.75 KiB]
Downloaded 150 times
PostPosted: Tue Mar 23, 2021 2:15 am  (#5)
Some of the scripts on here: https://kikidide.yuki-mura.net/GIMP/engimp.htm
have been updated and they are here on the forum. You just have to look for them.
PostPosted: Tue Mar 23, 2021 2:28 am  (#6)
Thank you so far ... with text it works well. With image not yet.
PostPosted: Tue Mar 23, 2021 6:19 am  (#7)
I have both logo and alpha to logo working. Didn't change title but translated all the Japanese comments in script.
Note that I've changed menu entries to main menu, where I have "Logos" & "Alpha to Logo" for quick access.
2028_mhkamifubuki.scm [5.29 KiB]
Downloaded 157 times
PostPosted: Tue Mar 23, 2021 6:42 am  (#8)
Thank you, it's all right now! :tyspin
PostPosted: Tue Mar 23, 2021 2:38 pm  (#9)
Nevermind.
PostPosted: Tue Mar 23, 2021 9:12 pm  (#10)
The file still needs procedures for gradients fixed.
cron
