It is currently Mon Sep 07, 2026 6:55 pm
 Post subject: Framed glass text
PostPosted: Thu Mar 25, 2021 12:26 pm  (#1)
Yes, here I am again. I found something nice again. Does not work in Gimp 2.10, but it works in 2.8
Here is an example and the file.
28_framed-glass-text.scm [19.87 KiB]
Downloaded 231 times
 Post subject: Re: Framed glass text
PostPosted: Thu Mar 25, 2021 2:16 pm  (#2)
28_framed-glass-text.scm [19.85 KiB]
Downloaded 237 times
Fixed.
PostPosted: Thu Mar 25, 2021 2:56 pm  (#3)
Thanks Mahvin!
PostPosted: Thu Mar 25, 2021 2:58 pm  (#4)
It only seems to work with size 100. Other sizes give an error.
PostPosted: Thu Mar 25, 2021 3:06 pm  (#5)
Sorry, I was wrong. Some numbers work and others don't for some reason. This was at 130.
PostPosted: Thu Mar 25, 2021 3:12 pm  (#6)
It's working for me at any size. Are you only changing the size and nothing else?
PostPosted: Thu Mar 25, 2021 3:13 pm  (#7)
No, I changed colours and pattern but that is all. I tried size 40, 60, and 150 and none of them worked.
PostPosted: Thu Mar 25, 2021 3:17 pm  (#8)
How peculiar - it's suddenly started working!!!
PostPosted: Thu Mar 25, 2021 3:21 pm  (#9)
Yep - it's working consistently now. Thank you.
PostPosted: Thu Mar 25, 2021 3:46 pm  (#10)
And I spoke too soon. It won’t allow over 512 px width.
PostPosted: Fri Mar 26, 2021 5:31 am  (#11)
This is one problem, line 383 which uses plug-in-edge. Putting in a large value for size into the script can give an error but it also depends on canvas size.
The plugin changed from
Gimp 2.8: amount FLOAT Edge detection amount
to
Gimp 2.10: amount FLOAT Edge detection amount (1 <= amount <= 10)
Probably not going to bother most users. however a quick remedy is fix the value of amount in the script.
PostPosted: Sat Mar 27, 2021 9:39 am  (#12)
I have a question: if you use this scm. file download, what else do you need to make it work. (e.g. bevel reflect logo)
PostPosted: Sat Mar 27, 2021 10:51 am  (#13)
to
The problem I am finding is a lack of scheme documentation that underlines the use of "if statementsconditions", involving other layers that are incorporated into the "float" number, chiefly for edgeBlurred, also including inFontSize and bb4, if the value is over 1. Not that I have stopped looking for more information. It's out there somewhere.
