It is currently Tue Sep 08, 2026 6:06 am
 Post subject: MH schadow.scm
PostPosted: Sun Mar 28, 2021 4:30 am  (#1)
Found another scm file that still works fine in Gimp 2.10.22. Nice result, I think!
2028_mhshadow.scm [7.21 KiB]
Downloaded 134 times
 Post subject: Re: MH schadow.scm
PostPosted: Sun Mar 28, 2021 5:19 am  (#2)
Easy to do with bumpmap, no need for script. I try to keep my scripts to a minimum.
PostPosted: Sun Mar 28, 2021 6:23 am  (#3)
You are right ... but I think the result is different
PostPosted: Sun Mar 28, 2021 8:59 am  (#4)
I think fuzzy select the black, convert to path, stroke path then adjust according to taste.
PostPosted: Sun Mar 28, 2021 11:37 am  (#5)
Good find Jappaloe. :) I'm sure someone will find a use for it. Thanks
