It is currently Tue Sep 08, 2026 5:01 pm
 Post subject: LucisArt effect
PostPosted: Wed Mar 31, 2021 3:28 pm  (#1)
LucisArt Pro
I have a cheeky question, can someone help me with this plugin ... was once free
http://itroshni.blogspot.com/2015/01/lu ... -free.html
 Post subject: Re: LucisArt effect
PostPosted: Wed Mar 31, 2021 7:34 pm  (#2)
Jappaloe63 wrote:
LucisArt Pro
The dropbox link doesn't work.
PostPosted: Sat Apr 03, 2021 9:37 am  (#3)
I could be wrong, but I believe this plug-in is dependent on Photoshop's internal filters, because I couldn't get it to run.
Gimp, and my "workhorse" Corel Photo-Paint both spat out a filter error, IrfanView did not respond at all.
The good news is that you can achieve same effect with Gmic pretty easily.
PostPosted: Sat Apr 03, 2021 10:42 am  (#4)
What kind of file is it because I have Adobe photoshop, could you tell me otherwise how I get the effect in G'mic?
PostPosted: Sun Apr 04, 2021 6:26 am  (#5)
It's 2x .8bf format plug-ins.
Edit: I forgot the pixls.us workflow has been scripted by Sébastien Guyader.
It should be close to LucisArt/Dave Hill effect. For my taste it looks a little soft. Have to test more I just downloaded it.
Not sure if there's something wrong with the script, the graphic novel layer that's in 50% opacity does not seem to change anything even at 100%.
https://www.gimpscripts.net/2020/10/hil ... cript.html
PostPosted: Sun Apr 04, 2021 7:11 am  (#6)
Thank you, I already found this one. You can also use an 8bf file in Gimp if you have the pspi. plugin download.
If you have the luscisart file and want to share it, I would like it.
PostPosted: Sun Apr 04, 2021 7:33 am  (#7)
I know, I know. I've always had the PSPI on my Windows machines. PSPI works with some (usually older) 8bf files.
It does not make LucisArt to run in Gimp, because of the thing I said earlier. It requires Photoshop.
PMd.
