It is currently Fri Aug 14, 2026 10:41 am
 Post subject: Tree Bark text plugin (test)
PostPosted: Fri Apr 09, 2021 12:56 am  (#1)
Hi folks! I'm here again, today i got my second vaccine for the Covid-19 and my body hurt just a little. I trying to write some plugin to get my mind going and without thinking about my aching body. I wrote this plugin and I know, that Tin trans has written one that you have to follow conbagui's tutorial the first 9 steps, then apply the plugin.
Well with my version you don't have to follow the tutorial. I made it straight through and you can have a nice tree bark text effect.
Please Test it and let me know how does it work for you.
Sample
create_tree_bark_text.zip [3.03 MiB]
Downloaded 130 times
 Post subject: Re: Tree Bark text plugin (test)
PostPosted: Fri Apr 09, 2021 5:03 am  (#2)
Thank you Pocholo. It works quick and great. No problem at all. :tyspin
PostPosted: Fri Apr 09, 2021 2:33 pm  (#3)
Thank you Issabella and you always welcome! :hi5
PostPosted: Tue Dec 28, 2021 5:51 am  (#4)
This script additionally neads 3d-extrusion.scm from here
viewtopic.php?f=9&t=9273
Regards
nelo
PostPosted: Tue Dec 28, 2021 11:30 am  (#5)
Thank you nelo. I did not noticed that the script was missing. I managed to place it inside the original file. :bigthup
PostPosted: Tue Dec 28, 2021 1:12 pm  (#6)
perfect! :bigthup
Regards
nelo
