It is currently Sat Sep 12, 2026 10:53 pm
 Post subject: How to do Sub-Procedures
PostPosted: Thu Apr 22, 2021 8:39 am  (#1)
Dear Community,
I need some help
In the Post :: viewtopic.php?f=9&t=19333
I have done some Coding.
And in General the Work was nearly Complete.
But:
Be warned, doing this:
Code: Select all
(define image 1)
(define layer 2)
Will define image and layer for ALL scripts and might break other scripts.
So this to do for all needed Variables is very COOL but only the half Work.
So I tried to do not only Local Variables but Local Procedures too.
The Problem is:
I can't find any documentation how a Local Procedure will done
or Is it possible to have Local Procedures
So In hope of Help
Thomas Lahme
 Post subject: Re: How to do Sub-Procedures
PostPosted: Thu Apr 22, 2021 9:07 am  (#2)
Here's a way of doing local functions:
(define (script-fu_kp24_thing image drawable message colour option)
  (let*
      (one 1)
      (two 2)
    (define (my_add first second)
      (+ first second)
    (define (my_multiply first second)
      (* first second)
    (define (id_numbers first second)
      (gimp-message (string-append "id1: " (number->string first) " id2: " (number->string second)))
    (gimp-message (number->string (my_add one two)))
    (gimp-message (number->string (my_multiply one two)))
    (id_numbers image drawable)
PostPosted: Thu Apr 22, 2021 9:52 am  (#3)
Ok,
I have edit my Program,
And my Local-Procedures are new not go direct Wrong
But it seams that the above by "let" defined Variables are not accessible from the Local Procedures
Can you please help me this Step to Runing-Code too.
Thanks
Thomas Lahme
PostPosted: Thu Apr 22, 2021 10:58 am  (#4)
  (let*
      (one 1)
      (two 2)
    (define my_variable 3)
      (+ first second)
      (* first second)
    (define (mult_by_variable first)
      (* first my_variable)
    (gimp-message (string-append "Before: " (number->string (mult_by_variable two))))
    (set! my_variable 4)
    (gimp-message (string-append "After: " (number->string (mult_by_variable two))))
PostPosted: Thu Apr 22, 2021 11:23 am  (#5)
Excuse me ;-)
I'm very new to Sheme - which is the Master-Language of Script-Fu
And I have never done anything with this before.
So please excuse my Beginner-Mistakes
But one Question more to your last Example in the last Post.
I have every time understand that a "Define" would create a global-Variable
So when I right understand you, inside a define Statement ...
... a inner "Define" would create a Global-Variable in this Define ...
Which is outer of the first Define a Local-Variable
Can you please say me is this new Understanding correct
In hope to learn the trick
Thomas Lahme
PostPosted: Thu Apr 22, 2021 11:47 am  (#6)
Defining a variable (or procedure) inside a define limits that definition to the scope of the parent.
So in my example, my_variable only exists within script-fu_kp24_thing and cannot be accessed outside of it, but can be accessed by procedures also defined within script-fu_kp24_thing because they are in the same scope.
Kevin
PostPosted: Thu Apr 22, 2021 12:06 pm  (#7)
Ok,
I'm anything like a little bit sleepy so I think I will try it Tomorow
By the Way you are in my temporary Experience:
1. The most helpful People I meet Today :paint
2. The most helpful People to learn anything in Computer Science. :geek
So my respect for you :mrgreen:
A happy
Thomas Lahme
PostPosted: Fri Apr 23, 2021 6:54 am  (#8)
ThomasLahme wrote:
Excuse me ;-)
You are of course aware that you can also write your scripts in Python?
PostPosted: Mon Apr 26, 2021 12:19 pm  (#9)
Yes I aware, but in the Days for Corona,
I have given Courses in Programming
And have made me my game to learn each necessary Programming-Language
Which is there outside in the Web of Community's
So I highly interested in Learning GIMP under Scheme.
So here Is my little Script which do by chance its Work.
And which most-fully don't Crash.
I have Commented the Code in the best I can.
But it must give a logical Mistake
== Which I will fix when I found it ==
So please is there outside anybody who find the Mistke
I will send you a Box of Sweets when you would call me the Mistake
File comment: This is my last Result.
When you have time to search the Mistake
Then please find the Mistake
When you find it tell me the Mistske
I swear I will give you a Box of chocolates
MyReadyMondrian.scm [4.66 KiB]
Downloaded 81 times
Thomas Lahme
