It is currently Sat Sep 12, 2026 6:03 pm
 Post subject: Help finding GMIC plugin
PostPosted: Thu Apr 22, 2021 4:29 pm  (#1)
Hello, Can someone help me find the GMIC plugin that detects transparency separated objects and breaks them into multiple layers. GMIC is a jungle of filters and I tried searching and had no luck finding it.
 Post subject: Re: Help finding GMIC plugin
PostPosted: Thu Apr 22, 2021 8:13 pm  (#2)
---UPDATE---
I found the filter I needed, it was called "Extract Objects".
PostPosted: Fri Apr 23, 2021 2:55 am  (#3)
Glad you found it :)
If you have this problem again, look up the top before the list of GMIC filters - there should be a search bar ;) Type in the filter or if you don't know the exact name a word that you are sure is in it and search will pull up a whole list for you. And show you where to look for it next time.
PostPosted: Fri Apr 23, 2021 10:47 am  (#4)
This is exactly why, when you find a G'mic filter you like to use,
you add the (modified) filter to faves and rename it with something that's easily identifiable or associative for you.
