It is currently Sun Sep 13, 2026 3:48 pm
 Post subject: SeamStress Updated to Version 1.2 for Gimp 2.10
PostPosted: Thu May 13, 2021 3:47 am  (#1)
SeamStress_v1_2.zip [4.71 KiB]
Downloaded 165 times
If you enjoy pattern making this small plug-in may help to speed up your workflow.
Download, unzip and add to your user plug-ins folder.
Create your basic design and call the filter from
Filters>>SeamStress v 1.2
Guide in PDF format...
SeamStress1point2_Help.pdf [1.61 MiB]
Downloaded 135 times
Examples below...
 Post subject: Re: SeamStress Updated to Version 1.2 for Gimp 2.10
PostPosted: Thu May 13, 2021 3:55 am  (#2)
The diagonal pattern follows GJL's method for creating seamless tiles.
Loads of patterns on GimpLearn
Seamless Pattern Link
First an example of scaling a design to create a tiled effect....
Using the plug-in to create a new tile with the 'Diagonal pattern' option...
PostPosted: Thu May 13, 2021 4:01 am  (#3)
An example using one of the block print type options (images from Wikipedia Commons) to create a basic Half brick tile with a transparent background:
Another tile created with the seamles 'Diagonal' option...
And the result with the two merged together...
PostPosted: Thu May 13, 2021 11:21 am  (#4)
:tyspin Skinnyhouse
PostPosted: Thu May 13, 2021 12:28 pm  (#5)
Turned out very well Lula - all your Gimping is of a very high standard. :clap :clap
If the first attempt doesn't work as well as you hoped, when patterned, it is worth repeating the plug-in one ot two times to see if things can be improved.
PostPosted: Thu May 13, 2021 2:56 pm  (#6)
Thank you for sharing!
PostPosted: Thu May 13, 2021 3:02 pm  (#7)
Thank you Skinnyhouse for this plugin which will be useful for me because I have always been annoyed with seamless tiles ;) .and thank you very much for your very detailed tuto.
PostPosted: Thu May 13, 2021 11:02 pm  (#8)
Lula, that is such a lovely pattern!
Skinnyhouse, not only are you a great font tool creator, now also great at pattern tools!
PostPosted: Fri May 14, 2021 12:51 am  (#9)
Thank you Skinnyhouse and Pat for your compliments.
I just have fun like you with Gimp and this is possible thanks to
the authors of the plug-ins and scripts. :clap :clap
PostPosted: Fri May 14, 2021 6:56 am  (#10)
Thank you Pat Level_0 and Lula.
Pat:
Of course the real reason for writing the plug-in was to use it for Custom Fonting purposes (as if you hadn't guessed).
