It is currently Tue Sep 15, 2026 2:51 am
 Post subject: "Metal Box" plug-in
PostPosted: Thu May 13, 2021 3:40 pm  (#1)
Hello, :)
Here is my new "Metal Box" plug-in.
It's not very creative but it's multilingual and adapted to both Gimp 2.8 and Gimp 2.10.
I've tested it on Gimp 2.8 + G'MIC 1.7.9 and Gimp 2.10 + G'MIC 2.9.7 in English, French, German (partial), Spanish (partial), Italian (partial). Feel free to add translations or to fix them.
Enjoy!
boxEffect.zip [1.71 KiB]
Downloaded 221 times
Photo to cartoon : https://github.com/cl4cnam/gimp_cartoon_plugin
 Post subject: Re: "Metal Box" plug-in
PostPosted: Fri May 14, 2021 6:05 am  (#2)
Pexels fox, in a metal box.
baby got secured like gold in Fort Knox.
Or is it tin can for herring? I think she might escape!
Thanks, works okay for me.
PostPosted: Fri May 14, 2021 9:22 pm  (#3)
CLI, I have tried to install your BoxEffect filter but it will not show up, even in the plug in browser. I am using a Windows 7, 64bit with GIMP 2.10.22. Anyone else having a problem?
PostPosted: Sat May 15, 2021 11:05 am  (#4)
Hello, :)
The filter should appear in "Filters -> Artistic". (It has to be put in the "plugins" directory)
I suggest that you try to launch Gimp from a command line and tell me which messages are written.
PostPosted: Sat May 15, 2021 11:19 am  (#5)
Yes, I found your plug, just where you say.
It works quick and the result is very nice. Thank you cli345. :tyspin
PostPosted: Sat May 15, 2021 11:39 pm  (#6)
I must have an incompatibility. It is not in "artistic". It was placed in my plug in folder. It showed in the Edit\preferences in a folder that all other .py files were working. It could not be found using the Plug in browser. When I closed GIMP and then re-opened, all my plug in folders were missing in Edit\Preferences. I tried placing the file in other plug in folders but could not get plug ins to work until I removed it from the computer. Afraid to try it again as took a lot of time.
PostPosted: Sun May 16, 2021 4:32 am  (#7)
Pat, remove the plug-in and close gimp even pass the cleaner and then install it again to see what happens.
PostPosted: Sun May 16, 2021 5:04 am  (#8)
A quick play; thanks for the plug-in.
PostPosted: Sun May 16, 2021 9:50 am  (#9)
Thanks Nidhogg, Pat625, Issabella, Oldmangrumpy for your feedback :) :tyspin
Sorry Pat625 that it took you a lot of time :oops: . If you have yet more time, you could remove the plug-in and try this one.
boxEffect_2.10_en.py.zip [1.64 KiB]
Downloaded 152 times
PostPosted: Sun May 16, 2021 2:10 pm  (#10)
Thank you cli345.
the plugin works well and fast as Issabella mentioned. :)
