It is currently Sun Sep 13, 2026 4:31 pm
 Post subject: SeamStress Updated to Version 1.3 for Gimp 2.10
PostPosted: Fri May 14, 2021 6:51 am  (#1)
SeamStress_v1_3.zip [5.17 KiB]
Downloaded 103 times
Sorry to update so quickly but ...
This update adds the option to create a second new image using the tile over a user defined area.
Please refer to the guide to version 1.2 for help.
 Post subject: Re: SeamStress Updated to Version 1.3 for Gimp 2.10
PostPosted: Fri May 14, 2021 7:40 am  (#2)
:tyspin Skinnyhouse :bigthup
PostPosted: Sat May 15, 2021 4:47 am  (#3)
Thanks Skinnyhouse for this great plugin to make quick and easy texture tiles.
PostPosted: Sun May 16, 2021 7:24 am  (#4)
This thing helps makes some very interesting patterns.
