It is currently Mon Sep 14, 2026 12:29 am
 Post subject: Naturalize Script
PostPosted: Sun May 16, 2021 7:43 pm  (#1)
When using EL Samuko's Naturalize script, I don't see anything happening and I have it listed in my menu twice.
What is supposed to happen when using the plugin?
 Post subject: Re: Naturalize Script
PostPosted: Sun May 16, 2021 9:02 pm  (#2)
It may be the case that without a highly saturated or at least over-saturated image you won't immediately see much change at all. The changes seem to be quite subtle. On the LAYERs tab, turning off the top black/white layer may make the changes more noticeable.
The script appears to use the "Calc Saturation" plugin, which, if you have it on your system, shows up under COLORS: COMPONENTS.
PostPosted: Sun May 16, 2021 9:31 pm  (#3)
Thanks neurolurker. :)
