This is probably the most simple plug-in I have made but it can produce some interesting effects with custom font characters.
Custom_Font_Edger_v_0_1.zip [3.76 KiB]
Downloaded 171 times
Download, extract and add to your user plug-in folder.
Some brushes that you may find useful when working with Edger:
Brushes.zip [78.13 KiB]
Downloaded 128 times
Download, extract and add to your user brushes folder/s.
The filter dialog has only three (yes three) options:
The plug-in allows you to control the paintbrush eraser along a path generated by the character alpha selection and erase chunks of the character.
The additional use of paintbrush dynamics and animated brushes allows room for a lot of experimentation; examples and dialog setting in the next post.
