It is currently Mon Aug 10, 2026 5:29 pm
 Post subject: StampifyG2 Script
PostPosted: Wed Jun 08, 2011 5:39 pm  (#1)
This is kind of neat. Make a postage stamp from an image.
Download it here
This is the script at default settings. You can find it in GIMP at Filters > Decor > Stampify.
 Post subject: Re: StampifyG2 Script
PostPosted: Wed Jun 08, 2011 5:50 pm  (#2)
That is really cute "O". I d/l and added to my scripts..... Thanks...
PostPosted: Wed Jun 08, 2011 6:48 pm  (#3)
Is this script running correctly now?
Lyle mentioned on the registry it had a couple problems with saving the original foreground/background colors..
PostPosted: Wed Jun 08, 2011 6:50 pm  (#4)
Knowing that caveat (Saul mentioned a few more), it's still pretty good at creating the outer teeth. Wonder how hard it would be o create it on arbitrary borders (like circles, triangles, or trapazoids for instance)? :)
PostPosted: Wed Jun 08, 2011 7:16 pm  (#5)
That script looks really neat O. Thanks!!
Liana
PostPosted: Wed Jun 08, 2011 7:42 pm  (#6)
It does work well creating the stamp effect.
PostPosted: Thu Jun 09, 2011 1:23 am  (#7)
StampifyG2
adapted for GIMP-2.7 and add a transparent option
Sorry for my poor English, I use Google Translate.
There may be something wrong, Please understand.
GIMP 2.10.38 rev1 portable+GAP+G'MIC+nufraw+Beautify+MathMap+...
PostPosted: Thu Jun 09, 2011 2:23 am  (#8)
Verified that your mod indeed works in GIMP 2.7.3 64-bit in Windows James; thanks. Tried to use it in 2.6x but it crashes. Tried following your logic and modified the code where I thought it would work but to no avail. Oh well. Hate coding mainly since I no longer have the patience for it anymore. lol
