It is currently Thu Aug 13, 2026 2:09 am
 Post subject: Words to shape
PostPosted: Mon Nov 22, 2021 12:41 pm  (#1)
Do you remember this one... Words to shape
Might be nice if a pattern can be added.
word_to_shape.scm [27.6 KiB]
Downloaded 246 times
 Post subject: Re: Words to shape
PostPosted: Sat Dec 18, 2021 10:34 am  (#2)
Pattern added? to the text? to the ornaments?
Have you seen this thread from Pocholo, WHite Christmas card plug-in v2 :
viewtopic.php?f=9&t=19712
(LeftyLeo/James)
PostPosted: Sat Dec 18, 2021 4:47 pm  (#3)
You should really be using Filters>Map>Map object to sphere for this. In four easy steps:
1) Create a rectangle image with aspect ratio = Pi (3.14...)
2) Add your colors and text
3) Image > Scale image and shrink it horizontally so that it becomes a square
4) Apply the filter
