It is currently Mon Nov 23, 2026 1:30 pm
 Post subject: Where to find links to older Gimp Scripts and plug ins
PostPosted: Thu Jan 20, 2022 12:15 pm  (#1)
I recall a link on this board that had many links to gimp plug ins. I have Gimp 2.10 on my new PC and Gimp 2.8 on my older lap top. I am looking for a data base or a list and or links to gimp script fu and plug ins if someone could help with that. Where can I find downloads to plug ins and script fu? Thank you.
 Post subject: Re: Where to find links to older Gimp Scripts and plug ins
PostPosted: Thu Jan 20, 2022 12:18 pm  (#2)
Is it this one ? https://www.gimpscripts.net/p/gimpscript.html
PostPosted: Thu Jan 20, 2022 1:27 pm  (#3)
What about this one?
viewtopic.php?f=9&t=18452
Regards
nelo
PostPosted: Thu Jan 20, 2022 10:38 pm  (#4)
[align=center]
The old registry which use to have a link at the top of the page is now defunct. The gimp scripts .net is the one you need to look for now as most of the things there are done for gimp vs 2.10 as well, they also have the older scripts in packages - if you have an older version of gimp I guess it's what you want.
There are 11 packs in zip files
Gimpscript.com archive
(213 plugins).
Gimpscript.com is only available through the archive:
PostPosted: Mon Mar 24, 2025 7:36 am  (#5)
This link is owned by a gaming site now .
As a new member i'm just ploughing through here looking for scripts and plugins that work on 2.10.25
Thanks
PostPosted: Mon Mar 24, 2025 11:20 am  (#6)
Thanks
Vanishing Gimp sites is a problem. gimphelp.org seems to be the latest.
If it is any help, I have bundled up files from gimpscripts / RobA / Saul Goode /gimphelp-org
https://limewire.com/d/BgpFT#xnuRTHobsr It is only there for a week, 38 MB zipped
The problem is, there is no description of what the file actually does, you have to look inside the .scm/.py and check the registration section.
PostPosted: Tue Mar 25, 2025 12:26 am  (#7)
https://sourceforge.net/projects/rods-c ... -FILES_RD/
You will find most of the plugins for Gimp here.
Two zipped folders. Very large files. All from GimpScripts.com after it was discontinued.
