It is currently Tue Sep 22, 2026 7:52 am
 Post subject: Update to Custom Font Bevel Reflect Tabbed for Gimp 2.10 to V1.09
PostPosted: Thu Feb 17, 2022 6:12 am  (#1)
Custom_Font_Bevel_Reflect_BRL_1_6_V_109_Tabbed.zip [17.75 KiB]
Downloaded 143 times
Download, extract and install to your user plug-ins folder.
Menu location:
Filters>>Custom Font Tools>>Custom Font Bevel Reflect V 1.09 Tabbed...
This update adds a 'Preview to new image' option to the tabbed version (tab 2). It allows the user to create a single character from a custom font file. The slow speed of rendering is still dictated by the the required call to the MLBevelLogo2 plug-in but is a lot faster than trundling through every character in a file.
There is also a new option on tab 1 to allow the user to return to creating emaps from the current colours/gradients after using emaps opened from files.
I have tested all options and they appear to function correctly but...
... if not please let me know!
 Post subject: Re: Update to Custom Font Bevel Reflect Tabbed for Gimp 2.10 to V1.09
PostPosted: Thu Feb 17, 2022 6:14 am  (#2)
An image of some previews generated as new images when using a small sub-set of characters.
PostPosted: Sat Aug 20, 2022 7:01 am  (#3)
Hi Skinnyhouse.
If 'Contour Options' is different from 'Linear' and 'Contour Depth'> 0 I get this error:
line 1353, in proc_apply_curves
    pdb.gimp_drawable_curves_spline(layer, 4, curve_num_segments[contour], curve_xy[points_ptr[contour]])
TypeError: wrong parameter type
PostPosted: Sat Aug 20, 2022 10:47 am  (#4)
:gaah
Hi M. Nice to hear from you.
I shall take a look and get back to you.
PostPosted: Sat Aug 20, 2022 1:24 pm  (#5)
:yes
Problem identified - solution forthcoming.
PostPosted: Sat Aug 20, 2022 3:49 pm  (#6)
Beautiful! :) :hi5
