It is currently Tue Nov 17, 2026 9:46 am
 Post subject: Make people metal with GEGL
PostPosted: Sat May 14, 2022 7:49 pm  (#1)
GEGL is moving this entire forum into the 21st century that includes live previews, presets, and eventually non-destructive filters.
https://github.com/LinuxBeaver/gegl-met ... -with-GEGL
The script fu engine doesn't stand a chance against Adobe CC but GEGL does. Enjoy the new GEGL filter.
 Post subject: Re: Make people metal with GEGL
PostPosted: Sat May 14, 2022 7:54 pm  (#2)
I just updated the filter to fix a typo.
PostPosted: Sat May 14, 2022 9:22 pm  (#3)
Version for Gimp-2.10.30 Win 64 Bit attached.
Place the file in Gegl plugins in a directory: ... \lib\gegl-0.4\
In menu Tools➤GEGL Operation➤Add a metal effect to subjects
Edit: an out-of-date attachment has been removed.
PostPosted: Wed Jun 29, 2022 12:01 am  (#4)
Update version for Gimp-2.10.30 / 32 Win 64 bit in attachment.
Edit:
The attachment has been removed because other builds are available.
PostPosted: Wed Jun 29, 2022 6:06 am  (#5)
Thank you so much MareroQ. Nice effect possible thanks to you. :coolthup
PostPosted: Wed Jun 29, 2022 11:08 am  (#6)
This filter is a combination of desaturate, alien map, noise reduction and hue-chroma's lightness. Other programs like Pixelitor use the term "solarization" for their Alien Map filter counter part. That is what inspired the name.
PostPosted: Wed Jun 29, 2022 1:09 pm  (#7)
contrast, thank you so much for making GEGL Options works. :tyspin
I thanked MareroQ his adaptation to windows 64, too.
PostPosted: Sun Aug 28, 2022 8:32 pm  (#8)
GEGL Bevel and Metallic make this
with Gimp:Colorize
Bloom and mean curvature seems to slightly improve it as well. If at least two people show interest I will make a filter of it.
Also some fonts it looks terrible
PostPosted: Mon Aug 29, 2022 1:04 am  (#9)
1) Count me in! :)
PostPosted: Mon Aug 29, 2022 1:22 am  (#10)
Looks useful
Regards
nelo
PostPosted: Mon Aug 29, 2022 1:32 am  (#11)
1) Count me in! :)
2) Me as well :bigthup
Patrice
PostPosted: Mon Aug 29, 2022 8:19 am  (#12)
I'll get to it and I have an idea to make it four steps to justify making a filter.
PostPosted: Mon Aug 29, 2022 9:41 am  (#13)
NOTE TO FORUM READERS -- THIS FILTER IS GEGL:CHROME! A FILTER THAT BRANCHED FROM GEGL METALLIC! GEGL:METALLIC IS NOT A TEXT STYLING FILTER ON ITS OWN WHERE AS GEGL CHROME IS.
Requires third party GEGL:Bevel, GEGL:Metallic and GEGL:innerglow
So much hype for the filter but it is
It's too complicated to turn into a filter. The only way I can turn this into a filter is if I downgrade it and the text will have rough jagged edges worse then Glossy Balloon.
Here's the graph and it will come with multiple variations. REMEMBER, Bevel, Metallic and stand alone InnerGlow third party operations are needed for this to work
median-blur radius=04 alpha-percentile=65
bevel th=0.096 azimuth=14  radius1=5  bevel1=65  th=0.1
metallic solar1=22 solar2=53 solar3=24 light=3
id=1
gimp:layer-mode opacity=100  layer-mode=split blend-space=auto composite-mode=auto composite-space=auto  aux=[  ref=1  innerglow grow-radius=3  radius=11 value2=#000000    ]
dst-over aux=[ ref=1 box-blur radius=1 median-blur radius=1   ]
bloom strength=10
unsharp-mask scale=0.2
softglow glow-radius=6
dropshadow x=6 y=4 opacity=0.75 radius=6  grow-radius=1
median-blur radius=04 alpha-percentile=30
id=1
bloom strength=10
median-blur radius=04 alpha-percentile=9
bevel th=0.096 azimuth=61  radius1=5  bevel1=65  th=0.1
metallic solar1=72 solar2=13 solar3=74 light=3
id=1
bloom strength=2
softglow glow-radius=2
PostPosted: Mon Aug 29, 2022 12:49 pm  (#14)
where would I find "bevel" ?
Regards
nelo
PostPosted: Mon Aug 29, 2022 12:51 pm  (#15)
Bevel is part of GEGL Effects. It comes with it.
The InnerGlow that comes with GEGL Effects is not the same stand alone innerglow as the one I have on github
PostPosted: Mon Aug 29, 2022 3:15 pm  (#16)
These require a
color-overlay value=#ffb386
in front of them for best results
crop
bevel th=0.096 azimuth=10  radius1=9 bevel1=65  th=0.1
metallic solar1=22 solar2=53 solar3=24 light=6 smooth=2
id=1
bloom strength=1
softglow glow-radius=4
noise-reduction iterations=3
dropshadow x=6 y=4 opacity=0.95 radius=4  grow-radius=1
PostPosted: Tue Aug 30, 2022 3:26 am  (#17)
This is my result.
I'm still on GIMP 2.10.28 ...
The filters produce a lot of errors, maybe because of that. The results look fine though.
I'll update GIMP only when the colour picker bug is really gone.
Maybe in 2.10.34...
Regards
nelo
PostPosted: Tue Aug 30, 2022 3:49 am  (#18)
One more:
Regards
nelo
PostPosted: Tue Aug 30, 2022 7:00 am  (#19)
Nice results contrast. :bigthup
PostPosted: Tue Aug 30, 2022 5:21 pm  (#20)
Good news! I reworked the graph and I know this new graph is possible to be turned into a filter. It doesn't even need innerglow. However, it will take a lot of work as it is still confusing. The final line is the hardest thing to put in the graph.
REQUIRES GEGL BEVEL AND GEGL METALLIC
bevel th=0.096 azimuth=60  radius1=3  bevel1=65  th=0.1
bloom strength=18
id=1  gegl:over aux=[ ref=1  xor aux=[  ref=1  median-blur radius=2 alpha-percentile=1    ] median-blur radius=2 alpha-percentile=55 percentile=9 gaussian-blur std-dev-x=1 std-dev-y=1  opacity value=2
median-blur radius=3 ]
Said final line in question is
it is possible to put in a graph the convention way but just really tedious to get the node connections right.
